Working with old dry wood
Forum topic by MonkeyDaddy posted 380 days ago 474 views 0 times favorited 7 replies Add to Favorites Watch
View MonkeyDaddy's profile
MonkeyDaddy
6 posts in 444 days
380 days ago
My parents tore down their old cabin and built a new one, reusing as much of the original material as possible. All the interior walls were made of 80-100 year old wormy pine. I have several of the extra pieces left over and would like to build a table for them.
My concern is the boards been indoors that whole time, untreated, and consequently are extremely dry. I can also put a decent dent in them with just a fingernail.
I jointed a test piece and it came out beautifully with little to no snipe.
I’d like to leave the wood looking as natural as possible but realize it will need some sort of protection against drink rings, scratches, dents, etc. Anyone have any recommendations for what to use? I may only treat the top table surface and leave the front/sides/back totally natural.
20733 posts in 719 days
380 days ago
If I were doing the build I would use wipe-on poly for the topcoat. It goes on easily and dries quickly. It will provide the table top with surface protection, it is a relatively hard finish and is unaffected by water. Its biggest drawback is that it is not as easy to repair as other finishes but, to me, its water resistance gives it the edge. But I would topcoat all surfaces so that subsequent moisture absorption will be uniform for the entire table top.
View drgoodwood's profile
drgoodwood
386 posts in 1024 days
380 days ago
My wood crafting style is rustic.
I use a lot of old and re-purposed wood.
You bring back some of the vitality of dry wood by first treating it with a drying oil.
I use a mixture of one part pure tung oil with two parts mineral spirits.
Be sure to use real tung oil, not “tung oil finish”, which, depending on the brand may not even contain tung oil.
Apply the tung oil mixture liberally, let it soak in for about 20 to 30 minutes, then wipe it dry.
Let it cure and dry for about 2 or 3 days.
If you want to use an oil stain, apply it now.
When you are ready to finish, first seal the wood with unwaxed Shellac, such as Zinsser SealCoat.
Then apply a top coat of your favorite finish.
I generally use polyurethane or a wiping varnish.
-- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower."
View Joey's profile
Joey
259 posts in 712 days
380 days ago
you can’t go wrong with the pure tung oil, i use it on pretty much everything i build for myself. i use close to the same mixture except mine is equal parts pure raw tung oil, BLO and poly. you get the warmth of tung oil and the protection of the poly without the build of straight poly.
-- Joey, Magee, Ms http://woodnwaresms.com
View brianinpa's profile
brianinpa
1365 posts in 620 days
380 days ago
What ever you do to the table top, you really should do to the entire table. A friend of mine varnished a table and only did the table top surface. Moisture was allowed to penetrate the table top from the underside through the concrete slab of his house, and the table warped so bad that he had to redo the table top.
I like straight tonge oil because it only gets better over time, and a new coat years from now will only add to the look.
MonkeyDaddy
6 posts in 444 days
379 days ago
Excellent. Thank you all for the comments and suggestions. I like the tung oil suggestion…I’ve used that finishing other projects and love the look of the finish.
One other question…from Joey’s post, what is “BLO”?
379 days ago
BLO is boiled linseed oil.
View rhchampagne's profile
rhchampagne
8 posts in 373 days
372 days ago
I recently made a dining table out of 200-300 year old oak planks. The finish for the whole piece is BLO with a coat of paste wax. In my experience, BLO will really darken old pine to a nice color and accentuate features such as old saw marks, dings, etc on the surface. Paste wax will give you a short term seal that can be easily replaced as the water resistance wears out. Plain old minway poly is also a great option if you don’t want to deal with the wax or you want a glossy film coat.
