thin spins
« back to Woodturning forum
Forum topic by REO posted 08-15-2013 02:29 PM 792 views 0 times favorited 1 reply Add to Favorites Watch
View REO's profile
REO
928 posts in 1975 days
08-15-2013 02:29 PM
Topic tags/keywords: diy lathe thin turnings router turning
A while back someone asked about getting some turnings done. They were thin, one end 9/16” the other 1/2” and a 3/8” section extending out of the smaller end for 1 1/4”. overall length was 12”. I had recently moved my equipment into a new shop and decided to overhaul the lathe. This would include an increase in diameter from 10” to 12” throw and a vfd. since I was changing the diameter there were changes that had to be made elsewhere. the lathe is capable of single pass but since the diameter changed i would need to change some things there as well. I ended up setting up in the DIY lathe. I tried several tool grinds and approaches. no mater how skimpy I left the last cut it would chatter. Finally I decided to make a router mount for the lathe and try that.
Here is the result http://www.youtube.com/watch?v=P12E08byJ6k&feature=player_detailpage
A shot from another angle http://www.youtube.com/watch?v=v_O-O1MpXx4&feature=player_detailpage
It was worth the effort 100 pieces from scrap to finished product in about three hours including the set up!
1 reply so far
View Bluepine38's profile
Bluepine38
3379 posts in 2987 days
#1 posted 08-15-2013 02:49 PM
Your background explains how you made this serious piece of heavy iron lathe. Very good and extra heavy
machine work. Thank you for sharing.
