What's this lathe tool called?
« back to Woodturning forum
Forum topic by JustJoe posted 08-14-2013 11:13 PM 1368 views 0 times favorited 7 replies Add to Favorites Watch
View JustJoe's profile
JustJoe
1554 posts in 2032 days
08-14-2013 11:13 PM
Topic tags/keywords: question lathe
I’ve got a lathe tool I bought a decade or so ago. I think it’s by Crown tools, but can’t find it on their website anymore. I just need to know what it’s called. First I’ll try with just a description, and hopefully someone can help before I have to break out the camera.
It’s not a conventional skew, gouge, scraper or diamond parting tool. It’s not carbide. The cutting tip is a ring with the bevel on the inside, like someone took a 1/2” piece of tapered pipe and beveled both openings and then welded the whole thing onto a lathe handle. One opening is slightly larger than the other. Supposedly if it’s sharpened correctly this wonder tool can hog out material on a bowl from one end, or remove shavings the size of gnats whiskers from the other. In my (less than) expert hands it has only proved capable of removing giant jagged chunks of wood the size of Montana from either end.
Anyone know what it’s called? I’m hoping to track down directions for correctly sharpening and using it somewhere on the internet.
thanks
Joe
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
7 replies so far
View woodsmithshop's profile
woodsmithshop
1318 posts in 3539 days
#1 posted 08-14-2013 11:32 PM
sounds like a Termite hollowing tool
check this out to see if thats’ what it is
http://www.woodcraft.com/category/2000411/termite-hollowing-tool.aspx
-- Smitty!!!
JustJoe
#2 posted 08-14-2013 11:37 PM
That’s pretty close. The shape is almost the same.Mine isn’t a removable tip, it’s a one-piece tool and it looks like mine tapered a bit more. I found an image on my computer with the tool and cut out most of the other stuff in the pic. It’s the middle thing here:
16274 posts in 4212 days
#3 posted 08-14-2013 11:45 PM
It’s basically the same thing Smitty posted. It’s a hollowing tool. Here is a video of how it works:
http://www.youtube.com/watch?v=jtMDAmQyBU0
JustJoe
#4 posted 08-14-2013 11:50 PM
Thanks, found it – it’s the Robert Sorby Ring Tool.
View Arlin Eastman's profile
Arlin Eastman
4211 posts in 2555 days
#5 posted 08-19-2013 06:41 AM
Joe
Mainly it is used for hollowing the inside of bowls or other bottom feeding cuts. I have one also and like using it.
You have to keep the angle right or it does not cut right. It needs to be tipped on its side about 22* to start cutting right.
Arlin
-- It is always the right time, to do the right thing.
JustJoe
#6 posted 08-19-2013 12:25 PM
Thanks Arlin, I found the original instructions online. Now I just need to get around to honing it.
View SteveKnnn's profile
SteveKnnn
66 posts in 1882 days
#7 posted 08-19-2013 07:07 PM
Sharpening that at the router table looks scary!
-- Steve in Richmond, VA
