How to clean dirty wood
Forum topic by boroughdan posted 08-14-2013 10:23 PM 3897 views 0 times favorited 7 replies Add to Favorites Watch
View boroughdan's profile
boroughdan
22 posts in 1968 days
08-14-2013 10:23 PM
I got some boards from a lumber yard that were stored outside. They are dirty. I tried spraying the board with the hose but that didn’t do it. I could get it pretty quick by running it through the planer but I hear dirty wood is murder on blades. Any advice?
Also I tried sanding, but the stuff is kind of rough so it would take a while to get a layer off.
7 replies so far
View richardwootton's profile
richardwootton
1699 posts in 1981 days
#1 posted 08-14-2013 10:40 PM
Wire brush then spray with a a high pressure nozzle? That’s what I did with some old barn wood I reclaimed and it got it much closer to being clean.
-- Richard, Hot Springs, Ar -- Galoot In Training
View Dallas's profile
Dallas
3599 posts in 2513 days
#2 posted 08-14-2013 10:42 PM
How about a picture?
Smaller stuff I would use a belt sander. Larger stuff I would use a draw knife and then the planer.
If it’s too large run it through the bandsaw and take off a veneer then sand or plane it.
(Hint, don’t use your best band saw blade).
View gfadvm's profile
gfadvm
14940 posts in 2716 days
#3 posted 08-15-2013 12:49 AM
That’s where I use the drum sander and some 50 grit paper.
View Loco's profile
Loco
210 posts in 1775 days
#4 posted 08-15-2013 12:58 AM
Bust out a belt sander with 36 or 40 grit and let’er rip. If you have no planer, take it to a cabinet shop when you have it “clean” A couple of passes won’t( shouldn’t) cost much.
Planer blades are often A2 or D2. A lil dirt cant mess with it much unless its an oily wood. Oily wood makes its own “rubbing compound” out of dirt. Ebony, Rosewood, Cocobolo,mesquite, certain Cordias etc can whip a blade if there is sand-dirt involved.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
18351 posts in 1882 days
#5 posted 08-15-2013 01:22 AM
I use a brush that goes on my angle grinder. It is kind of like a wire brush but is made of plastic bristles impregnated with some sort of abrasive. It is made for working on a log home. Wire brush on angle grinder would work too.
View Tim's profile
Tim
3812 posts in 1987 days
#6 posted 08-15-2013 03:06 AM
Bill that sounds like a good idea, but that brush costs $50 for the ones I could find. Good wire brushes do too, but seems like they would hold up longer.
When I was searching I found this LJ link from a similar question. Recommended drum sander, belt sander, and cheap planer and/or old planer blades among other things.
#7 posted 08-15-2013 03:13 AM
Yeah it is expensive, but I bought it about 13 years ago and it is still good. I brushed my whole log home with it, another guy used it for his house and its still usable. All those ideas should work too.
