Is this fixable?
Forum topic by Doug posted 08-14-2013 09:04 PM 828 views 0 times favorited 4 replies Add to Favorites Watch
View Doug 's profile
28 posts in 2023 days
08-14-2013 09:04 PM
Topic tags/keywords: question purpleheart maple
Last weekend I decided to make an end grain cutting board from some scraps. After my final glue up was dry I noticed that I have huge gaps between the boards(largest around 1/16”). Needless to say I was very disappointed because I thought I had taken care when I glued it up. Anyway my question is if there is any way to fix these gaps? Or should I just chalk it up as a learning experience?
View Hammerthumb's profile
2826 posts in 1905 days
#1 posted 08-14-2013 09:57 PM
Re-cut the joint and re-glue. That is what I would do.
-- Paul, Las Vegas
View JayT's profile
5536 posts in 2141 days
#2 posted 08-14-2013 10:10 PM
+1 on the cut and re-glue. Also a chalk it up to learning and use the opportunity to learn a new skill—fixing and covering mistakes. That is the most useful skill a woodworker can learn.
#3 posted 08-14-2013 11:01 PM
Yeah I thought about re cutting it but it is already fairly narrow for a cutting board so I didnt go that route. Maybe thats the only possibility though. Thanks for the input.
View waho6o9's profile
8126 posts in 2507 days
#4 posted 08-14-2013 11:16 PM
Mine was a little messed up as well. So, I cut it apart, added a piece,
glued it up and made two of them as that fit my customer’s needs.
After it’s finished it’s difficult to spot a mess up.
Yours will turn out fine Doug. Good luck on your decision.
