Age, Value, Identity of Jessem Table?
Forum topic by PatrickIrish posted 08-14-2013 02:29 AM 983 views 0 times favorited 5 replies Add to Favorites Watch
View PatrickIrish's profile
PatrickIrish
131 posts in 2284 days
08-14-2013 02:29 AM
Seller is asking $550 for this Jessem table with 3hp Porter Cable. I’m waiting on more pics and thought I’d ask around on a perceived value. I was going to offer $400 since I’m about 90 minutes away drive.
What is the model of this table and lift? I cant tell from the pics. Looks like an older master excel system.
Thanks
Rc
5 replies so far
PatrickIrish
#1 posted 08-14-2013 07:06 PM
Got in touch with Jessem and it’s a Mast-r-Excel table system that includes the Mast-R lift. Bought 4-8 years old.
Would $400 offee be reasonable?
View PurpLev's profile
PurpLev
8548 posts in 3887 days
#2 posted 08-14-2013 07:15 PM
it’s an older design that as far as I remember didn’t really become all too popular for some obvious (to some) reasons. it’s a nice “all in one” but I don’t believe it has a quick lift mechanism to quickly bring the router above table for bit changes (a really nice feature in many lifts), also I don’t recall seeing a plate on that table since the entire lift is part of the table itself (lifting mechanism is wheel on edge of table which is linked with a chain to the actual router lift -so everything is “one piece” – that means again that for changing bits, you’d have to turn that wheel all the way up and back all the way down – a hassle in my opinion.
all that for 550 – is not worth it in my view, even 400 is too high of a mark – 300 and under I might consider. but still even at that cost, I would probably get a stand alone table top, and a quality stand alone lift for not much more without all the limitations this one has to offer.
that’s my story and I’m sticking to it ;)
PatrickIrish
#3 posted 08-14-2013 11:47 PM
Thanks for the reply. Cranking the blade all the way up to change a bit isnt a big deal for me, considering something new will be easily $800+ . New this system was over $900 with the porter cable 3hp.
I could build a table but a new lift is $300 and materials. Can’t see it being less than $500.
View Gene Howe's profile
Gene Howe
11157 posts in 3667 days
#4 posted 08-15-2013 12:05 AM
If you get it, buy a bare crank rod from Jessem ($5.00) and find a cordless drill at a swap meet ($7.00). Chuck up the rod and you have a power lift. That’s what I did and it has saved me countless “wasted” minutes.
BTW, $400 is decent. As you said, you cannot build one for that.
PurpLev
#5 posted 08-15-2013 02:30 PM
I missed the “with PC router” – that changes the perspective considerably. I thought it was just for the table. yes with the router this is a good deal.
that said – most of my use of the lift is to quickly bring the router above table and back to previous position for quick bit changes – and not so much for fine adjustments as one would think (at least I did at the time).
