Coarse thread/fine thread
Forum topic by melliott posted 08-14-2013 01:33 AM 911 views 0 times favorited 7 replies Add to Favorites Watch
View melliott's profile
melliott
28 posts in 1916 days
08-14-2013 01:33 AM
Hi all….I am building new beds for my kids. I picked up some hardware to attach the siderails to the headboard and footboard and I was just wondering what type of screw would be best to use for attaching the hardware. They are made from pine and I dont want the screws to pull out over time. Do they have a Loctite for wood screws like they do for machine screws? Any help is greatly appreciated…...Mike
-- Mike
7 replies so far
View RussellAP's profile
RussellAP
3103 posts in 2194 days
#1 posted 08-14-2013 01:55 AM
For pine that is likely to get a lot of stress, I’d use a lag bolt whenever possible. Screws won’t hold in pine for something that gets as much stress as a kids bed will. Actually if it’s not where you can see it, I’d use both if I could. Also consider a through tenon but re-enforce it with some metal like they use for joist hangers, you can nibble the excess away. Or consider using oak for the frame parts that cant be seen, like the legs and matress and boxspring rails. Be sure to screw in the support slats to the side rails, or they will flex out and keep falling out.
17567 posts in 1764 days
#2 posted 08-14-2013 02:01 AM
What I have started to use is a lag screw that is made by the same company that makes the exterior torx screws that I use. It is a lag screw but with a torx head. It is very aggressive threads and looks better than galvanized.
RussellAP
#3 posted 08-14-2013 02:10 AM
Lag screws are good, just dont over tighten it in pine, or the threads might strip. I prefer to use a bolt and washers on pine for these types of connections where reinforcing would be awkward.
View tefinn's profile
tefinn
1222 posts in 2345 days
#4 posted 08-14-2013 02:32 AM
Since you asked what screws to attatch the “hardware” with, I’m guessing you bought a side rail connecting system of some type. If the hardware doesn’t have or recommend a certain screw, use the longest coarse thread screw that doesn’t penetrate the side rails and fits the holes in the hardware. I usually use http://www.rockler.com/product.cfm?page=11&site=ROCKLER or http://www.rockler.com/product.cfm?page=5783&site=ROCKLER. Both come with specs on what screws are required.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View babarracus's profile
babarracus
3 posts in 1662 days
#5 posted 08-14-2013 02:57 AM
An option I haven’t seen mentioned is a cross-dowel/knockdown nut: http://www.rockler.com/product.cfm?page=30249&site=ROCKLER
But then you either have to counterbore the bolts or have them visible.
melliott
#6 posted 08-14-2013 04:17 PM
Thanks everyone for the advice.
-- Mike
View MrRon's profile
MrRon
4634 posts in 3151 days
#7 posted 08-14-2013 07:46 PM
Use a 1/4”-20 hex head bolt, fender washer and a locknut at each point where an attachment is made; usually 2 per attachment point. The fender washer will spread out the clamping force of the bolt/nut.
