Sliding horse stall door
Forum topic by Laughran posted 08-13-2013 02:22 PM 4949 views 0 times favorited 16 replies Add to Favorites Watch
View Laughran's profile
Laughran
70 posts in 1837 days
08-13-2013 02:22 PM
I. Have a friend who wants me to build 3 sliding horse stall doors. Have any of you built horse stall doors? I’m looking for any advise or tips or direction on the best materials and construction.
Thanks
-- David
16 replies so far
View Dallas's profile
Dallas
3599 posts in 2395 days
#1 posted 08-13-2013 02:36 PM
I’ve built many over the years.
I use cannonball track for the slide and usually 2 or 3 layers of CDX plywood sandwiched between 1x covering on the outsides.
Horses are tough on doors and fences. using layers of plywood inside makes it strong, (alternate the grain direction). Using the 1x construction on the outside makes it look good.
And a horse can’t kick through it nearly as easily.
Laughran
#2 posted 08-13-2013 04:32 PM
Thanks Dallas, Plywood sounds like a good way to go. Should be strong and easy to build
-- David
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3493 days
#3 posted 08-13-2013 05:22 PM
But my sister could eat through it ,she has dentures with 28 tungsten carbide teeth.I tried to poison her once but as the policeman said after 60 years of eating her own cooking she had built up an imunity. LOL Alistair
Dallas
#4 posted 08-13-2013 09:44 PM
Alistair, it would take her awhile though…..
View gfadvm's profile
gfadvm
14940 posts in 2598 days
#5 posted 08-14-2013 01:42 AM
I would try really hard to talk them out of sliding doors for safety reasons. I have seen several horses injured when they laid down, rolled, and kicked the door out at the bottom catching their leg between the door and the wall.
Just my opinion after 38 years in equine practice.
View jusfine's profile
jusfine
2422 posts in 2834 days
#6 posted 08-14-2013 02:06 AM
The detail Dallas has given you would work the best in my opinion as well.
We have had sliding doors on our stalls for 27 years, never an incident when all the proper hardware is in place.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Bluepine38's profile
Bluepine38
3379 posts in 2994 days
#7 posted 08-14-2013 02:18 PM
The problem gfadvm mentioned is because many people do not want clean out the bottom track or brackets
needed to properly hold a sliding door in place and tend to eliminate them, making life easier for them, but
tougher for the horses. Please advise the client of the possible problem.
Dallas
#8 posted 08-14-2013 03:34 PM
I never used a bottom track, but instead used a piece of well casing, (2” or 3”) buried in a concrete footer on each side of the door frame then filled the pipe itself with concrete.
I’ve seen the injuries Andy spoke of, they aren’t pretty and I would personally use 2 piece swing doors. I just think they look a lot better plus there are so many options for hinges and styles.
gfadvm
#9 posted 08-15-2013 12:09 AM
Gus/Dallas, Thanks for chiming in. I knew others out there had seen the sliding door wrecks. I have hinged doors at my place and in all the hospital stalls. The other advantage of hinged doors is the door can be used as a guide wing to get a foal to enter the stall.
Dallas
#10 posted 08-15-2013 12:17 AM
Andy, My heart doctor, (was actually a company commander in my old battalion, then went on and became a Dr.), had me build him a stable for 16 horses with 2 birthing stalls.
He wanted sliders on all the doors until I took him to a neighbors place and showed him what problems could happen.
We went with the dutch door style with the separate top and bottom. (Of course, then he wanted 3 cuploas on the roof to make it look like Louisville Downs!
gfadvm
#11 posted 08-15-2013 01:04 AM
I spent much of my youth chasing foals that couldn’t find the door opening on sliders.
Laughran
#12 posted 08-15-2013 01:04 AM
Thanks for all the information. I will tell my friend what I learned here. Now back to making the doors. Dallas, do you leave the plywood edge as is or do run a band around the edge?
-- David
Dallas
#13 posted 08-15-2013 11:48 AM
David, I have done it both ways, but I think it looks more professional to finish it with a band of solid wood.
Bluepine38
#14 posted 08-15-2013 01:51 PM
gfadvm, sometimes I think foals and calves were put here just to make sure us humans that thought we were
in control would get some necessary exercise and taught a little humility.
Dallas
#15 posted 08-15-2013 01:52 PM
Gus, you sure got that right!
