Router speed. Looking for answers
Forum topic by Jofa posted 08-12-2013 05:41 PM 805 views 0 times favorited 3 replies Add to Favorites Watch
View Jofa's profile
Jofa
272 posts in 1839 days
08-12-2013 05:41 PM
Hey LJ’s. I just picked up a Makita RT0700C hand held router and I had some questions.
Up to now, I’ve been using a single speed Skil router that is mounted on a table. It’s a big ‘un and has worked ok for the time I’ve had it.
I grabbed this Makita because I’m just sick of having to unmount the Skil every time I want to do work on a larger piece.
So last night I used it to roundover cuts I made for a plywood deck for one of my pedalboards. At first I had it set at the maximum speed and it seemed to leave a bit of a rough edge. Then I tried it at about 2 of 6 on the speed dial and the results were fantastic. Very clean, no burning.
So my question is, how should I be using the speed adjustment? Do I go with a higher speed for harder stock and vice versa for softer woods? Any suggestions for different speeds for cutting dovetails or box joints?
Thanks.
-- Thank you Lord for the passion and ability to make things from your creation.
3 replies so far
View GrandpaLen's profile
GrandpaLen
1650 posts in 2273 days
#1 posted 08-12-2013 07:19 PM
Jofa,
Here is a Link, http://woodworking.about.com/od/safetyfirst/a/RouterBitSpeeds.htm , to an article and a ‘Speed Chart’ that you may find helpful.
This is a tip from Wood Magazine for storage and quick reference of Speed for your bits, which I use.
http://tips.woodmagazine.com/wood-routers/speed-guide-adds-purpose-to-router-bit-storage/
Hope you find these helpful.
Best Regards. – Grandpa Len.
Work Safely and have Fun.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View Jofa's profile
Jofa
#2 posted 08-12-2013 11:09 PM
Grandpa Len, this is exactly what I was looking for. Thank you very much!
GrandpaLen
#3 posted 08-13-2013 10:42 AM
You’re welcome Sir, glad I could help.
Work Safely and have Fun. – Grandpa Len.
