newbie dealing with discolored plywood
Forum topic by JHarshaw posted 08-12-2013 07:07 AM 1162 views 0 times favorited 2 replies Add to Favorites Watch
View JHarshaw's profile
JHarshaw
8 posts in 1842 days
08-12-2013 07:07 AM
Topic tags/keywords: plywood finish
I have some 3 yr old oak plywood that I am making into shelves. Some of the surfaces were exposed to sunlight apparently, as they are discolored- slightly darker shade. Unfortunately, the stain/discoloration is at times in the middle of a surface.
I hesitate to try sanding it out since I’ve read the surface layer is typically very thin and its easy to sand thru it.
Can I leave it as is and hope the gel stain masks the difference? Are there other ways to fix this? Any help is GREATLY appreciated!
2 replies so far
View Knothead62's profile
Knothead62
2584 posts in 2989 days
#1 posted 08-12-2013 12:28 PM
You should be able to see the thickness of each layer by looking at the end. I would think that sanding a bit should tell you how deep the coloration goes into the wood. If push comes to shove, you could paint it.
View Brice11's profile
Brice11
8 posts in 1749 days
#2 posted 09-09-2013 07:16 AM
Hello Everyone!
My name is Brice and I am 20 years old. I am new to this forum, hope to spend a good time with all of you. Wish you all the best
