What am I doing wrong?
« back to Scrollsawing forum
Forum topic by lumberjoe posted 08-12-2013 02:19 AM 1823 views 0 times favorited 17 replies Add to Favorites Watch
View lumberjoe's profile
lumberjoe
2894 posts in 2123 days
08-12-2013 02:19 AM
So I’ve had a scroll saw for about 8 months and I finally decided to give it a shot tonight. No matter what I do, I cannot follow a line. It seems when I put pressure on the blade, it wanders. I’ve tried speed, more tension (bad idea) less tension (bad idea) and different blades. I practiced on a piece of cherry – about 3/8 thick with a No2 Olson plain end blade.
Any good places to look for the basics? I’d really like to start scrolling as I have a few projects in mind that would benefit from some fretwork
17 replies so far
View b2rtch's profile
b2rtch
4847 posts in 2923 days
#1 posted 08-12-2013 09:28 AM
I never used a scroll saw in my life, did you check YouTube or other videos?
https://www.google.com/#bav=on.2,or.r_cp.r_qf.&fp=9e2c13b57a36ff47&q=how+to+use+scroll+saw+video
-- Bert
View Handtooler's profile
Handtooler
1493 posts in 2007 days
#2 posted 08-12-2013 09:48 AM
ASK LJ Sheila Landry! She’s the real McCoy. Go to blogs or Jocks, find her and drop her a PM. She’ll be glad to stop her busy chores of the day of painting, pattern making and scrolling solve your problem. Keep us advised, Please.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View CFrye's profile
CFrye
9974 posts in 1714 days
#3 posted 08-12-2013 11:00 AM
I’m no expert either. Here are a few who are…
Sheila Landry (Scrollgirl) did a LJ series of classes here.
Steve Good explains cutting a straight line on a scrollsaw here.
Helped me understand.
As with anything it takes practice. Your first inlay cutting board wasn’t perfect…keep trying!
-- God bless, Candy
View americancanuck's profile
americancanuck
367 posts in 2484 days
#4 posted 08-12-2013 11:01 AM
Go to the classes section here on lumber jocks and find Sheila Landrys series on scroll sawing. It was invaluable to me when I started and I still go back and look at it all the time.
-- Retired and lovin it
Handtooler
#5 posted 08-12-2013 11:48 AM
Candy, Thanks for Steve Good’s video It’s invaluable knowedge
View HorizontalMike's profile
HorizontalMike
7727 posts in 2789 days
#6 posted 08-12-2013 12:54 PM
Since no one has mentioned “feed rate”, I will. Scroll saws are small scale cutters and NOT like BSs and TSs. You need to slow down… a lot. Also note that some woods with coarse grain will cause the blade to jump/follow the grain. Just my 2-cents…
View scrollsaw's profile
scrollsaw
13032 posts in 3729 days
#7 posted 08-12-2013 01:50 PM
Make sure your blade is not loose and take your time.The more you scroll the better you will get
-- Todd
View kepy's profile
kepy
293 posts in 2148 days
#8 posted 08-12-2013 02:09 PM
You might want to try a softer wood to get you started. The main thing is to let the saw do the work without forcing. A little larger blade for beginning might also help (maybe a #5 or 7).
-- Kepy
lumberjoe
#9 posted 08-12-2013 03:37 PM
Thanks guys. Candy, that’s what I was looking for.
Mike, you are correct. I think my major problem problem is balancing stroke speed and feed rate. I need to find a good combo that works. If I feed slow I find I have to use more pressure than I like and the blade really wanders/deflects. Too fast of a feed and the tracking is waaaay off.
From my experience with other tools (routers, bandsaws, jigsaws), the results I was getting indicated a major tool setup issue since no matter what I did I could not get a proper cut. After looking at some of the stuff mentioned here, technique plays a very large role.
View distrbd's profile
distrbd
2252 posts in 2321 days
#10 posted 08-12-2013 04:55 PM
I am a total newbie with a scroll saw(and woodworking in general).For me ,in order to cut straight ,I always sit to the right of the blade and feed the piece I’m cutting towards the left(slightly) and forward.
Another tip I learned from an old timer is: it is alright to go back and forth ever so slightly ,to cut on the line.
I hope this helped,there’s a great scroll saw you can check out,great members and lots and lots of info:
http://www.scrollsawer.com/forum/
-- Ken from Ontario, Canada
View RolfBe's profile
RolfBe
28 posts in 1689 days
#11 posted 08-21-2013 12:38 PM
I have been scrolling for about 8+ years and have learned a few thing in that time.
First all blades tend to cut to one side (with a few exceptions) that is because of how they are manufactured. There is a burr that will cause them to cut to your right as you face the saw. You learn to compensate for that.
The main thing is to use quality blades Olson, Flying Dutchman, Pegas to name a few. The next thing is blade tension. Judy Gale Roberts had a great audio file on her site that gives you an idea on how the blade should sound. Another thing is to look where you are going not where you have been like when you drive.
Once you remove the pattern no one will know that you wandered off the line.
-- "I don't know that I can't, therefore I can" Hawk G4 ss, New Nova 16-24 DVR XP
View DKV's profile
DKV
3940 posts in 2379 days
#12 posted 01-14-2014 04:11 AM
Lumberjoe, is your problem completely solved. Any revelations you care to share? Thanks,
-- This is a Troll Free zone.
View lanwater's profile
lanwater
3111 posts in 2809 days
#13 posted 01-14-2014 04:16 AM
lumberjoe, I have mine for 3 over 3 years and I only used it a handful of time.
I cant cut strait or make an angle. I am also rushing.
-- Abbas, Castro Valley, CA
lumberjoe
#14 posted 01-14-2014 04:23 AM
Yeah. 1 word – DRIFT. I’m able to do some pretty acceptable scrolling now that I figured out the drift angle of my saw. That was the biggest thing setting me back. it gets tricky when the piece changes directions. I have to remember what side of the line/pattern to keep the blade on so I am working against the drift instead of letting it wander.
I’m not sure if this is normal, but instead of trying to fight with it, I made friends with it. Also playing with FPM and feed rate was a big help. I tend to speed things up (both) when doing long sweeping curves or straight portions, then slow things down when it’s about to get intricate – not unlike driving a high performance vehicle at it’s edge.
View DKV's profile
DKV
#15 posted 01-14-2014 08:42 AM
Thanks lumberjoe. Every little bit of feedback helps.
