My blade Comparison: Forrest WWII, Freud P410, & Freud LU84R011
Forum topic by Marcus posted 08-10-2013 07:32 PM 5379 views 0 times favorited 6 replies Add to Favorites Watch
View Marcus's profile
Marcus
1163 posts in 2192 days
08-10-2013 07:32 PM
I thought it would be fun to pit the Forrest WWII up against the Freud P410. I had a hard time choosing between the blades about a year ago and ended up with the Freud. It was in need of some sharpening so I sent it to an authorized Freud center, but in the meantime, got the itch and picked up the Forrest WWII. I wanted to compared these 2 against the stock blade that came with the G1023 table saw I bought last year, but couldnt track it down, so found my old Freud LU84R011 and put it in the mix instead.
Blade Details
Forrest WWII: About $125 New. I had only used this blade to make one or two cuts before this test. It was basically new out of the box.
Freud P410: About $100 new. Mine is about a year old. I actually just knicked my miter gauge, hence the need for sharpening. In my mind, a freshly sharpened Freud and a new Forrest would be about as close as I would ever get to testing these two new. When I got the blade back, it was scary how sharp it was. I actually sliced my finger accidentally on a tip, first time that had ever happend.
Freud LU84R011: About $65 new. I dont know the details on this one. I know I used it for about a year, never sharpened it. It seems to be in pretty good shape except for in need of a serious cleaning.
The Victim
I bought this curly maple from a cabinet maker going out of business. I remember him telling me “be careful, that maple burns if you look at it wrong”. He was right and I’ve fought it since. I very rarely have burns after cutting lumber except w/ this wood.
As a side note, I am not SUPER anal about setting up my table saw, but try to keep everything aligned pretty well. The blade is in line w/ the miter gauge and the fence kicks out at the end about .005”.
Comparison
The dust shavings on these were all a bit different. The WWII spat out more chips than dust. The P410 created mostly dust but a few nice shavings. The LU84 was all dust.
WWII
P410
LU84
Next I made a thin cut of 1/32 with each of these. My rankings are as follows
WWII
9/10
Smooth/Even
P410
7/10
1 minor swirl mark, Even
LU84
5/10
Tough to push, inconsistent cut, swirl marks.
Cross Cut
WWII
9/10 Smooth
7/10 Tear Out
P410
9/10 Smooth
9/10 Tear Out
LU84
6/10 Smooth
7/10 Tear Out
Dado
I through this category in although I never make finish cuts like this with these blades. I notice it seems to show tear out though, so did it here.
WWII
6/10
P410
9/10
LU84
6/10
Ripping
WWII
9/10 Smooth
8/10 Burn
P410
8/10 Smooth (a few more rough tear out spots)
6/10 Burn
LU84
4/10 Smooth
5/10 Burn
So what did I prove here? Not much other than I can come up with some interesting ways to get out of mowing the lawn. For me personally, I think Im going to use the WWII for the time being. I think it did the best with ripping which is alot of what I use the table saw for. I was kind of surprised at how the P410 did with ripping, so maybe a freshly sharpened blade isnt equivalent to a new blade. The LU84 will probably sit in a corner indefinitely. Now only did not not rate up there with the big boys, I could tell I had to push significantly harder to get it to cut. A good sharpening might do it wonders though.
View knotscott's profile
knotscott
8138 posts in 3548 days
#1 posted 08-10-2013 08:23 PM
I can’t think of a better reason not to mow the lawn! Maple is very prone to burning, and the P410 has a dual side grind which puts more of the side of the tooth against the wood…. which can also increase burning (unless the sharpener change that parameter). Try a few different species of wood, and try a slightly higher blade height….those variables could change your results.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3087 days
#2 posted 08-11-2013 01:28 AM
In my limited TS blade experience, I find the “feed rate” to an important factor in controlling burning on maple. I also find that with my two push-stick feeding, that I can actually cause more burning if I apply too much pressure on the left stick (holding down and against the fence).
BTW, I am now using much more Bostik Dricote (now labeled “BladeCote”). This does seem to help in my case.
http://compare.ebay.com/like/321078517815?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Marcus
#3 posted 08-11-2013 03:07 AM
Don’t get me wrong, I’d be happy with either of the top two blades. I just wanted to do a real world comparison between the two in a situation where I know there would be issues (burning on maple). Maybe give someone else out there something to think about if they’re considering these two blades.
View Carloz's profile
Carloz
1147 posts in 764 days
#4 posted 11-22-2017 03:52 PM
So… You take a brand new blade of one brand and some old blade of another brand that was never sharpened and needs “serious cleaning.” and try to compare cuts.
I am not sure what that proves.
Marcus
#5 posted 11-22-2017 03:58 PM
- Carloz
It proves people have way too much time on the internet to complain about 4 year old threads I suppose! Have a good thanksgiving!
View Gilley23's profile
Gilley23
489 posts in 555 days
#6 posted 11-22-2017 03:59 PM
Just for comparisons sake of how stark the differences are between a blade that seems sharp and a blade that truly is. Moral of his comparisons: a sharp blade is your friend.
Thanks for taking the time to do this and post up the pictures, even if it was a few years ago.
- Carloz
