Lower Band Saw Wheel wobble
Forum topic by justbob posted 08-09-2013 01:54 PM 3610 views 0 times favorited 13 replies Add to Favorites Watch
View justbob's profile
justbob
16 posts in 2004 days
08-09-2013 01:54 PM
I own an older delta 14 inch band saw circa 1973 The lower wheel has a noticeable wobble. How can it be removed?
13 replies so far
View Bill White's profile
Bill White
4856 posts in 3866 days
#1 posted 08-09-2013 01:57 PM
The wheel or the wobble? Not tryin’ to be a smart a$$, just want to better understand your question.
Bill
-- bill@magraphics.us
justbob
#2 posted 08-09-2013 02:01 PM
When you watch the wheel spin you can see the run out.
Bill White
#3 posted 08-09-2013 02:18 PM
Let me try this again. Is the wheel loose on the bearing, or is the wheel itself warped?
justbob
#4 posted 08-09-2013 02:49 PM
the wheel is not loose on the bearing so it must be warped I am guessing there is no easy fix for that.
View rrww's profile
rrww
263 posts in 2019 days
#5 posted 08-09-2013 03:05 PM
Are the bearings good? If they are at all ” gritty” feeling or you can hear them they may be bad. A bad bearing can fail and still spin freely. This is where I would start it’s a cheap fix if that is the problem. I can’t really think of how a wheel would warp, but I’m sure anything is possible.
If you grab the wheel (facing it head on) and wiggle it is there any play side to side?
justbob
#6 posted 08-09-2013 03:51 PM
thanks I’ll look at that
justbob
#7 posted 08-09-2013 07:46 PM
tried to look at the bearings but the wheel won’t come off. Is it pressed on the shaft? I can see a key on the shaft, I don’t want to beat on the wheel and make it worse than it is.
View MrUnix's profile
MrUnix
6353 posts in 2105 days
#8 posted 08-09-2013 08:54 PM
The wheel is a slip fit. If it appears stuck, give it a few taps with a rubber mallet or 2×4 and it should pop off. You can also give the shaft a tap or two from the front to loosen it up. The rear bearing is a slip fit and will (should) easily back out when you do. Front bearing is a press fit and will need to be driven out from behind with a wood dowel or something similar. Also, some ‘wobble’ on the wheel is acceptable and in most cases will not cause any problems. You should only be concerned about it if you see some really noticeable front/back motion of the blade when running the saw. Have you tried running it as is to see how it performs?
View Surfside's profile
Surfside
3389 posts in 2079 days
#9 posted 08-09-2013 08:56 PM
When did it start wobbling? To keep the wheel true, it should be mounted securely on a trued shaft. Guessing this might be also a bearing issue. Check this blog . The guy had a problem with the lower wheel, he explained how he fix the problem step by step.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
justbob
#10 posted 08-09-2013 09:15 PM
tried tapping the wheel went as far as giving it a few good whacks wouldn’t budge. I don’t want to beat on it too much.
View Loren's profile
9958 posts in 3554 days
#11 posted 08-09-2013 09:39 PM
Squirt some PB blaster in there and let it sit and work it’s way in.
I’d lay the saw on its back personally in order for the stuff
to go with gravity. Also, with the weight on the ground,
you can pull up on the wheel to get it off.
I suppose the shaft could be bent.
You’re not talking about a lumpy tire, right?
View Syed Sirajuddin's profile
Syed Sirajuddin
7 posts in 1357 days
#12 posted 06-05-2014 03:34 PM
Try to tap the wheels and look at the bearings. I think the problem is in bearings, which is making the wheels to wobble.
-- http://bandsawdepot.com/best-band-saw-reviews/: Ultimate Portal for Best Band Saw Reviews
View Jim Finn's profile
Jim Finn
2622 posts in 2828 days
#13 posted 06-05-2014 06:56 PM
I just replaced the wheel shaft on my GO555 and it would not come out with tapping nor with hammering. I used a gear puller and pushed it out. It was a long hard push! The new one went in with a few light taps from a plastic mallet and some WD-40. The bearings were fine but the shaft was worn badly where ti bearing sat, causing a thump thump as the saw ran. See my post today>>> http://lumberjocks.com/topics/61449
