Fiberglass coated router table top questions
Forum topic by ColonelTravis posted 08-09-2013 05:48 AM 1377 views 0 times favorited 11 replies Add to Favorites Watch
View ColonelTravis's profile
ColonelTravis
1953 posts in 2132 days
08-09-2013 05:48 AM
Topic tags/keywords: router table fiberglass
For the past few months I’ve been looking (very off and on) for something cheap to make a router table top. By “cheap” I mean what I pay for it, not the material – something more smooth and durable than MDF and melamine. Haven’t been able to find anything, which has been frustrating – until I stumbled on a guy selling sheets of fiberglass coated plywood for pretty cheap. The sheets are either 1/2 inch or 5/8 inch thick, and I’d put that on top of some 3/4 inch birch plywood I have sitting around. So:
1.) Is this a good choice for a router table top?
2.) Haven’t seen the finish, not sure how smooth it is. Would you need to coat it with anything after sanding, or just sand it?
3.) When I cut the hole for the plate, or round off the sides, is this stuff easy to chip?
3a.) How do you avoid chipping?
Thanks
11 replies so far
View ChrisK's profile
ChrisK
2017 posts in 3319 days
#1 posted 08-09-2013 12:23 PM
MDF with a high pressure laminate is probably the flattest least costly way to go. The fiberglass will be a durable surface and you can sand it smooth, until you sand through to the glass. Cutting the hole wont be fun. The glass fibers can be hard on steel blades. Making it flat could also be a real chore.
My 2 cents? 3/4 MDF with laminate scrap from a big box store over the birch ply with a nice hard wood trim band.
I have been using laminate over MDF for almost 10 years on my router table. (Used Poplar trim coated in BLO, it was what I had on hand.)
-- Chris K
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#2 posted 08-09-2013 01:28 PM
Formica is the way to go, easy to work with and easy to get. Fiberglass while durable, is a bear to work with and you absolutely need a dust mask for grinding, sanding or sawing it. Fiberglass should be painted as well as it should be protected from UV rays.
-- Bondo Gaposis
View GNP's profile
GNP
12 posts in 2740 days
#3 posted 08-09-2013 01:49 PM
I have to agree on the MDF with laminate. I picked up a laminate scrap from a local cabinet shop for free. Used it on the fence too. Good luck with your router table.
View Bill White's profile
Bill White
5148 posts in 4198 days
#4 posted 08-09-2013 02:04 PM
Don’t know what size top you’re lookin’ for, but I picked up a couple laminate (Formica) sink cut-outs for free, glued ‘em back to back, edge banded them. Total cost? ZIP, nada, nothing. Been usin’ that top for 10 years w/o a single prob.
Bill
-- bill@magraphics.us
16281 posts in 4456 days
#5 posted 08-09-2013 02:12 PM
I guess my questions would be: 1) How smooth is the fiberglass? and 2) How cheap is the guy selling it?
If it’s quite smooth, and you can get it cheaper than you can buy plywood and Formica, I don’t see a problem. But I’m guessing that’s not going to be the case.
View Clint Searl's profile
Clint Searl
1533 posts in 2599 days
#6 posted 08-09-2013 02:18 PM
Dumb idea.
View crank49's profile
crank49
4032 posts in 3209 days
#7 posted 08-09-2013 02:27 PM
Bill makes a very good point about gluing two panels back to back.
That’s the key. Someone else on here recently posted a comment about having some of that material (single sided laminate counter top) laying around for over a year before they went to use it and it had cupped.
Gluing two sheets back to back avoids that problem. Sealing the edge with a trim of solid wood is just extra protection. Best way to go in my opinion.
Come to think of it, do you suppose the guy selling “fiberglass coated” plywood really is selling phenolic coated plywood and just doesn’t know what he has? I ask that because I never heard of the former, but the latter is fairly common and really good stuff; but expensive.
ColonelTravis
#8 posted 08-09-2013 04:03 PM
Alrighty – no go on that board. Thanks very much for the input.
What I really want is the free counter formica but haven’t been able to find it. I live next door to a contractor and asked him about picking up an old counter when they do a remodel. He said nope. Couldn’t believe it. He’s not a jerk, either.
I live in DFW Texas – there’s gotta be a billion contractors who have something to throw away, I just need to find out how to find one of them. Do I just call remodeling companies up cold?
crank49
#9 posted 08-09-2013 05:48 PM
You could go to a Home Depot or Lowes, or similar, and get the names of people who install sinks and or kitchen counters, etc. Then contact these people to see if you could obtain any sink cut-outs.
For that matter, HD or Lowes might have a damaged section of counter top they would give you, or sell real cheap.
Bill White
#10 posted 08-09-2013 06:01 PM
There’s gotta be a cab or countertop fabricator in your area. The sink cuts are trash to them. Check out the yellow pages or your cab contractor.
Bill
View Earlextech's profile
Earlextech
1162 posts in 2928 days
#11 posted 08-09-2013 06:33 PM
Clint – a man of few words. LOL
I’ve had an MDF/laminate covered router table top for almost thirty years. Still as flat as the day I made it.
I’ll bet you could go by a cabinet shop and pick something up for free or really cheap.
