Simple cabinet doors?
Forum topic by Al Killian posted 384 days ago 305 views 0 times favorited 7 replies Add to Favorites Watch
View Al Killian's profile
Al Killian
271 posts in 651 days
384 days ago
I am starting a waitress station and planed on useing some shaker type doors. These will my first ones like this. How thick should the center panels be if the doors stiles and rails are 3/4” thick? Was thinking 3/8”, but wanted to check before I cut the maple.
20771 posts in 720 days
384 days ago
1/4” is a fairly common dimension for flat panel doors (actually it is the nominal thickness of the plywood, if that is what you are using). 5/16” also makes a pretty solid door. A true Shaker style door is in reality a raised panel door with the raised panel installed facing the interior of the cabinet. This type can be either 5/8ths or 3/4 thick depending upon your style (flush with the face frame or proud). In either case the panel mounts in a 1/4” groove in the door.
View 8iowa's profile
8iowa
592 posts in 660 days
383 days ago
Actually a rather attractive and easy paneled door can be made by dadoing 1/4” grooves in your stiles and rails and using 1/4” plywood for the panel. I built paneled doors like this for my eight foot long cabinet pictured in my “Workshop in the Woods” blog.
For the stiles and rails I used 3/4” x 3” wide white pine, and the panels are inexpensive luan plywood. A clear finish of polyureathane gives a pleasing contrasting color. This was an easy door to make.
View Loren's profile
347 posts in 546 days
383 days ago
I wouldn’t go much thinner than 3/8” with a solid wood panel – too
fragile. To do what you want to do you raise the panel on the back
so it fits a 1/4” groove set 3/8” back in the frame, which only leaves
you 1/8” on the back of the groove – which is kinda fragile.
I would try to get wood milled 13/16” if I were you at least.
You can also use ply and it’s plenty strong and fine where
authenticity isn’t needed.
-- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html
Al Killian
383 days ago
Thanks, I think I am going to go with a peice of ply then veneer it. By the end of the week the cabinet should be done.
View rhett's profile
rhett
160 posts in 566 days
383 days ago
If using plywood for your panels, keep in mind that 1/4 ply is actually about 3/16 thick. It will leave an unsightley gap inside your rails and stiles. You will need to use 1/4 mdf core with desired wood veneer facing. If using solid wood, don’t forget the space balls.
-- http://www.efcabineture.com/ You can be tired, or you can be broke, but you should never be tired and broke.
View BigBob's profile
BigBob
59 posts in 388 days
378 days ago
You can make some nice frame and panel doors quickly and accurately with one $20 bit and a router table.
Get a slot cutting bit with a bearing and a 1/8” slot bit. Set up the fence on a router table to be even with the bearing, or bury the bit in a zero clearance fence.
Take your 3/4” stock and cut your rails and stiles to exact lenght. Now take your panel and if it’s 1/4” or if you veneer, slighly larger and mark it’s thickness (panel) on your stock, right in the center. Raise the slotting bit to cut the first pass. Cut a 1/8 groove (rabbet) in all the pieces, the rails need a backing board to prevent tearout in the endgrain.
Then raise the bit slightly to cut to the final thckness using a test piece of panel to get a perfect fit.
Finish the final pass on all parts.
You can use solid stock or ply as a loose tenon to glue up the doors for the rails and stiles.
The doors can be made very quiclkly and look great.
Hope that helps you.
View Treverk's profile
Treverk
20 posts in 378 days
378 days ago
I’ve had really good results using Norm’s method for grooves. Set the blade height on the TS and set your fence so that the blade is centered on your frame material. Run your stock through and flip it so the opposite face is against the fence. Check the fit of the ply and move the fence ever so slightly and try again. With this method you get perfectly sized grooves that are centered and you don’t have to listen to that awful router whine.
-- Matt, Minneapolis, www.treverkdesign.com
