Pair of nightstands - first furniture project - insight appreciated
Forum topic by Spur posted 08-08-2013 01:14 PM 1172 views 0 times favorited 4 replies Add to Favorites Watch
View Spur's profile
Spur
87 posts in 1904 days
08-08-2013 01:14 PM
Going to start a pair of nightstands for the master bedroom in the next 2 weeks, once the master bath remodel is complete. I have in mind approximately what I would like to do but I am hoping someone has some rough plans they can link me to, and suggestions of pitfalls to avoid (I would rather not firewood anything).
I have the walnut veneered plywood ready for the sides and will be picking up the walnut in the next few days for the top, drawer fronts and rails/stiles. I have an idea of how drawers are supposed to work, but pictures of assembly in addition to the flashlight I am using to peer into existing furniture would probably not hurt :)
I am thinking of a sort of 3 drawer shaker style with a little bit of flair. I am very worried about the solid walnut for the top warping due to humidity change. I am not sure if in a house that is an issue, but I want to make sure to do it right.
Finally, I want to do a nice glassy smooth finish. Suggestions for type of finish to use and how to apply would be excellent :)
I know I can probably dig up a lot of the stuff I am curious about in the forums here (I have done a lot of digging) so if you feel I am being a pest by not searching the forums here (which I have) please know that I have already imagined the angsty replies and choose not to respond instead. My reasoning is I am looking for insight with specifics to my project, all in one place, with potential for stuff I have not found in the forums. Thanks folks!!!
-- Henryk, South Carolina
16272 posts in 4095 days
#1 posted 08-08-2013 01:56 PM
I’ll chime in on a couple of your questions.
First, warping of a solid walnut top should not be an issue if you are buying kiln-dried lumber from a dealer. You do want to use a tabletop fastener that allows for wood movement when you attach the top to the skirt. I like these, but there are other types out there as well.
Second, for a glassy-smooth finish on walnut, you are going to want to use a grain filler. I like a product called CrystaLac, but again, there are many other types out there. It’s a thick, clear-drying substance that fills the wood’s natural pores, which you then sand flat to give you a smooth base for top coating. My suggestion for final finish on a nightstand top would be oil-based wipe-on poly. It may take a half-dozen coats or more to get a really smooth finish. If your surface does not look as smooth as you would like after a good number of coats, sand pretty thoroughly with 400 grit and add another coat or two. If you really want to go the extra mile, give it a final rubbing out with automotive polishing compound.
View Lee Barker's profile
Lee Barker
2170 posts in 2727 days
#2 posted 08-08-2013 03:32 PM
Just one design comment, Henryk. When I’m building a nightstand I try to figure out a height that makes it easy to read the clock radio numbers when one needs to. Bed heights vary lots so there’s no real “typical” nightstand height.
Kindly,
View Spur's profile
Spur
#3 posted 08-08-2013 03:57 PM
Thanks guys!
What’s the shelf life on CrystaLac? Is there a brand of oil based poly I should lean to or away from?
#4 posted 08-08-2013 05:17 PM
I don’t really know about the shelf life on the CrystaLac. I bought some for a project and went back and used it again at least a year later without a problem.
As for wipe-on poly brands, I use Minwax just because it is readily available and I have no complaints with it.
