Card Scraper vs Scraper Plane
Forum topic by BigMig posted 08-07-2013 03:35 PM 1902 views 0 times favorited 5 replies Add to Favorites Watch
View BigMig's profile
BigMig
427 posts in 2582 days
08-07-2013 03:35 PM
There’s a lot of discussion going on in another thread about card scrapers. I’ve (finally) developed a little skill and confidence with a card scraper and recognize what a great tool it can be.
But if I use a card scraper a lot, my hands/thumbs get fatigued and sore. Does a scraper plane achieve the same results? What are the benefits/tradeoffs between the two tools? Is one better for certian types of wood, or in certain situations?
-- Mike from Lansdowne, PA
5 replies so far
View Douglas's profile
Douglas
424 posts in 2528 days
#1 posted 08-07-2013 03:40 PM
Great question, and I’m in the same boat as you… Handy now at sharpening a card scraper, but looking to add a no 80 to my collection. I look forward to the replies!
-- Douglas in Chicago - https://dcwwoodworks.com
View JustJoe's profile
JustJoe
1554 posts in 2007 days
#2 posted 08-07-2013 03:40 PM
I use both. The card scraper can be used to attack a tiny area the size of a dime, the scraper plane covers a much larger area. If you want to give your thumbs a break, Veritas makes a scraper holder that does the flexing for you. I’ve had one for a while and it works nicely.
http://www.leevalley.com/en/wood/page.aspx?p=32669&cat=1,310
I don’t remember it being so d@$%ed expensive though. If you look up cheap in the dictionary, you’ll see my picture. I’m sure I didn’t pay that much for mine. I think if you google/bing/yahoo or ask Jeeves you might find plans for a shopmade scraper holder that isn’t so obnoxiously overpriced.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View PurpLev's profile
PurpLev
8534 posts in 3617 days
#3 posted 08-07-2013 03:44 PM
card scraper has a better reach to corners and tighter areas that a plane can’t access.
plane addresses larger area and is faster to dress an area with
try putting less flex on the card so you don’t overwork your finger/thumbs. you just need to flex it “enough”, but not so much that it’s a workout.
View OSU55's profile
OSU55
1636 posts in 1958 days
#4 posted 09-10-2013 07:48 PM
From the sound of it you are using a scraper a significant amount, probably on larger surfaces. If the surface provides the room, a #80 cabinet scraper or a scraper plane will not only relieve your hands and fingers, it will do a superior job of flattening a surface vs a card scraper. I use all manner of scrapers depending on the surface location/shape/orientation and the type of work. The negative to scraper planes is cost and there has to be room to use them (A #80 can be had for <$20 though). They also can snipe at the trailing edge until you learn how to use them.
The #80 gets used for the “dirty jobs”: clearing panel glue joints, cleaning off a weathered surface before planing (dirt, rocks, etc that brushing/vacuuming doesn’t get), scraping off old finishes, etc. I’m lucky enough to have the Veritas small and large scraping planes, so I use them for finishing jobs and some finish removal, but a #80 will finish scrape very well. There is a learning curve in sharpening, burnishing, and using these tools, but they work great. Burnish a hook on the blade, and remember they are for whisper thin shavings. Most of the trouble people have with these tools is not adjusting them for a fine enough cut.
I also have the veritas card scraper holder, a very nice tool. The amount of blade flex can be adjusted, no heat gets to your hands, and it is far easier on hands and fingers. I don’t use it a lot, because I use the scraper planes instead whenever possible. I plan the project out to use the planes as much as possible, then the holder, then bare handing a card or curved scraper.
View Don Niermann  's profile
Don Niermann
218 posts in 3941 days
#5 posted 09-10-2013 08:06 PM
The 80s are great. I keep two ready for action
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
