Grain filler OVER polyurethane?
Forum topic by lateralus819 posted 08-07-2013 01:25 AM 4801 views 0 times favorited 8 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 2087 days
08-07-2013 01:25 AM
I’ve got a few coats of poly on my table top (sapele). I sanded it back and some pores are still visible. Is there a fill that can be applied over the poly? It’s oil based wipe on.
8 replies so far
View shampeon's profile (online now)
shampeon
1878 posts in 2381 days
#1 posted 08-07-2013 01:50 AM
It’s common in luthier circles to grain fill a contrasting color after sealing, so I’d say you’re probably fine as long as the poly has cured.
View kdc68's profile
kdc68
2691 posts in 2474 days
#2 posted 08-07-2013 02:31 AM
lateralus has a great question….shampeon what would you recommend for a filler that can be applied over poly?
-- Measure "at least" twice and cut once
shampeon
#3 posted 08-07-2013 03:00 AM
In this case, I think an oil-based filler would be more appropriate. I’ve used Timbermate and Target Coatings fillers, and those are water-based.
404 - Not Found
2544 posts in 3166 days
#4 posted 08-07-2013 09:05 AM
Pour on some poly, spread it out and into the pores with something flat, wait to dry, cut it all back flat with p180, add more coats of poly as required.
lateralus819
#5 posted 08-07-2013 09:52 AM
Ah renners, are you talking about basically using a squeegee of sorts to impact it into the pores?
View rrww's profile
rrww
263 posts in 2310 days
#6 posted 08-07-2013 12:37 PM
Thats what I do- work it with a squeegee & sand back and do it again if it needs it. I like general finishes arm-r seal. Then I topcoat.
Good luck
404 - Not Found
#7 posted 08-07-2013 12:53 PM
That’s right, I keep my old planer knives for doing this, or a plastic spreader. This works for me but I urge you to try it on a test piece first, and don’t allow any drips to form on the edges (wipe away with a ms wet rag).
View mahdee's profile
mahdee
4020 posts in 1965 days
#8 posted 08-07-2013 01:02 PM
Poly is a pain if you want a descent looking finish. Rub on is ok for the final touch but to start with, use brush on. Give it a thick coat and depending on humidity, wait 3-4 hours and sand with 220G. Then give it another coat and sand after a day or so; then another and another if necessary. I wouldn’t put anything but poly over poly. Good luck
-- earthartandfoods.com
