bent lamination or cut from solid block of wood
Forum topic by CudaDude posted 08-06-2013 10:52 PM 827 views 0 times favorited 1 reply Add to Favorites Watch
View CudaDude's profile
CudaDude
179 posts in 2337 days
08-06-2013 10:52 PM
I need to reproduce a curved back for a chair. The piece is 6” wide and seems pretty curved to me. I was planning on trying bent lamination but my concern is with making a cut that “tall” on the bandsaw. Do you think the thickness will be consistent from top to bottom of the cuts.
-- Gary
1 reply so far
View jumbojack's profile
jumbojack
1677 posts in 2653 days
#1 posted 08-06-2013 11:12 PM
With proper set up and execution-YES. That said even if you are a little off cut your pieces a skosh thick and run them over the jointer and through the planer. Now you have good flat even pieces. Glue them up in your form and you are golden. You would need to clean them up a little anyway, as coming straight off the band saw would not make a very reliable gluing surface.
