Want to buy: Dust collector accessory for Delta planer
Forum topic by dougomatic posted 08-06-2013 06:19 PM 3305 views 0 times favorited 6 replies Add to Favorites Watch
View dougomatic's profile
dougomatic
4 posts in 1722 days
08-06-2013 06:19 PM
Topic tags/keywords: planer dust collector 22-560 50-445 delta
I am looking for a dust collector accessory for a Delta 22-560 planer.
The Delta part number is 50-445.
I would also consider an aftermarket part, if it works well.
-- Nampa, Idaho woodworker says: " making holes in wood is faster with a gun (unless you care about tearout)"
View Chris208's profile
Chris208
239 posts in 2237 days
#1 posted 08-06-2013 06:43 PM
I have the same planer, and the same problem. I’ve seen shop built solutions on here, but havent had time to make one myself. The delta part is no longer available, and i havent seen any aftermarket replacements.
I see you’re in Nampa. I live in Boise and work in Caldwell. Maybe we can come up with a solution and batch out a couple for our planers.
Chris
Chris208
#2 posted 08-06-2013 06:44 PM
dougomatic
#3 posted 08-08-2013 04:04 PM
Chris,
That is possible, should be easy to do. The advantage is using a smaller hose connection without adapters.
I am working on a plan, I’ll let you know what I come up with. What size hose do you want to connect?
Chris208
#4 posted 08-08-2013 04:14 PM
It would be a 4 inch hose.
Thanks! Let me know.
View James 's profile
James
138 posts in 2893 days
#5 posted 08-09-2013 03:58 AM
Let me know what you guys come up with. I have the same planer and same problem.
View Kwit's profile
Kwit
103 posts in 1926 days
#6 posted 08-16-2013 01:04 AM
dougomatic
Here’s my thread for the dust hood I built
http://lumberjocks.com/topics/47919
Hope it helps
-- don't talk about it - be about it
