Tool gloat or not?
Forum topic by Gonecrazy posted 08-05-2013 11:43 PM 893 views 0 times favorited 6 replies Add to Favorites Watch
View Gonecrazy's profile
Gonecrazy
41 posts in 2435 days
08-05-2013 11:43 PM
I just picked this ryobi drum sander up for $70 … is it a gloat or not ? ... I never knew ryobi made drum sanders at one point all I know is that they dont any more ….. it works great and not in bad condition … I read the original reviews on it and the bad points were all pretty trivial to me ….. its the 1600 model … 16/32 sanding drum just for info
View rrww's profile
rrww
263 posts in 2019 days
#1 posted 08-05-2013 11:44 PM
I had the same one it worked good – but I hated the clips for the sand paper they suck. Do yourself a favor and convert it to velcro.
I sold mine for $375 a year ago- I say you did great!
View ShaneA's profile (online now)
ShaneA
6889 posts in 2505 days
#2 posted 08-06-2013 12:25 AM
Gloat!
View toolie's profile
toolie
2106 posts in 2535 days
#3 posted 08-06-2013 12:37 AM
definitely a gloat. i got mine for $225 two years ago. and yes, the inside spring clip near the drum support is difficult to tension so it grabs the paper. i found using a “t” handle screwdriver, that i got from a WW rag, was just the right size to wedge in place so that when the drum was rotated, the spring clip opened. once the paper end was slid into position, i release the drum and the spring clip griped the paper. you might try contacting jet for the special purpose tool they include with their DSs that performs the same operation.
does that one have an OEM rubber drive belt or was it changed to the aftermarket sandpaper belt?
Gonecrazy
#4 posted 08-06-2013 12:48 AM
it still has the rubber mat …. and the clip is the one main bad review ive read …. the other is a set up issue cause the mat only rotates while the drum is spinning … this is my first drum sander so i dont know how sustantial that is.
View ,'s profile
2387 posts in 3453 days
#5 posted 08-06-2013 12:51 AM
Velcro is inexpensive conversion and will provide excellent results. Supergrit.com can help.
Congrats
Shawn Masterson
1324 posts in 1855 days
#6 posted 08-06-2013 01:19 AM
May I be the first to say
you suck
you suck
you really really suck
(with harmony to go along)
just teasing Nice score
