Mathematically challenged
Forum topic by woodklutz posted 08-05-2013 08:50 PM 839 views 0 times favorited 4 replies Add to Favorites Watch
View woodklutz's profile
woodklutz
221 posts in 2851 days
08-05-2013 08:50 PM
I am trying to make a cutting board from 30degree cuts. Problem is this. Blanks measure 1 5/8 wide. I set my 30deg stop 1 5/8 from cut each successive cut follows with no deviation,1 side comes out 1/4 wider even though all is set true. What am I doing wrong? Sorry for the description being so fuzzy.
I am winding up with a rhomboid which I don’t want.
-- honing my craft one mistake at a time.
View PurpLev's profile
PurpLev
8539 posts in 3732 days
#1 posted 08-05-2013 08:57 PM
what is this “30 degree stop” that you are setting? are you setting up the blade at 30 degrees bevel? or are you setting a stop on your miter gauge which is set to 30 degrees from perpendicular to your blade?
a cut at 30 degrees (or a triangle with a 30 degree angle) will always have 2 legs which are of different lengths… if your cut was at 45 degrees, than you would get 2 legs of equal lengths.
maybe a picture would help others decipher what you refer to?
View RogerM's profile
RogerM
792 posts in 2482 days
#2 posted 08-05-2013 10:09 PM
As already noted by PurpLev, the only triangle that will have equal legs is a one with two 45 degree angles and a 90 degree angle. Note that if you add up all angles in a triangle they will always equal 180 degrees. From this, a 30, 60, 90 degree triangle will have two legs and a hypotenuse (the longest side of a right triangle, opposite the right angle) that have the ratio of 1, 2 and the square root of 3 (1.732). That is, one leg will always be twice the length of the other and the hypotenuse will always be 1.732 times the shortest leg. Hope this helps.
-- Roger M, Aiken, SC
PurpLev
#3 posted 08-05-2013 10:14 PM
...unless you are trying to use triangles which are 60 degrees angle on each corner – then you should have a triangle with all 3 legs being equal – but that is a 60 degree cut, and not 30.
edit: (sorry, been a looooong day).... or a triangle with 30/30/120 angles… in which case you’d have 2 equal legs…
so I go back to my initial question – what exactly are you setting up, and what are you trying to accomplish? a pic (or a link) is worth a 1000 words.
woodklutz
#4 posted 08-05-2013 11:33 PM
You guys are great, thanks for the wake up. Should have paid more attention in geometry.
THANK YOU ALL1111
