Has anyone built a base for this?
Forum topic by ohtimberwolf posted 08-05-2013 07:06 PM 859 views 0 times favorited 6 replies Add to Favorites Watch
View ohtimberwolf's profile
ohtimberwolf
749 posts in 2258 days
08-05-2013 07:06 PM
Topic tags/keywords: jet bandsaw jwbs-14cs bandsaw 14 bandsaw
If you have built a base for the Jet JWBS-14CS Bandsaw (or know of a post of someone who has) I sure would like to see it. I have to build one to hold the saw and the motor. Hope to put it on a rolling base but any build ideas will help. larry
-- Just a barn cat, now gone to cat heaven.
View MrUnix's profile
MrUnix
6351 posts in 2104 days
#1 posted 08-05-2013 07:59 PM
Simple angle iron and MDF. Wheels are attached using some all-thread, pads on the other side are made from old work boots :)
ohtimberwolf
#2 posted 08-05-2013 09:00 PM
Did you put something in the lower area to hold the motor or did you bolt it right to the metal? Where did you get that kind of metal? The feet for the pads look good, did you make them? larry
MrUnix
#3 posted 08-07-2013 11:23 PM
The motor is attached with a couple more pieces of angle iron and an old hinge:
The other side ‘floats’, but is held in place with a captive bolt and spring, allowing tension to be adjusted:
Didn’t make the flared feet, but I’ve seen it done with just a torch, hammer and angle grinder. A quick search over at OWWM might give you some additional ideas.. there are pictures and descriptions of all sorts of bases from really minimal to full bore faux cast iron with extreme functionality.. it’s really up to your imagination and skill set as to how fancy the end result is. The base on my BS came with it, but was obviously a hand made deal. I simply cleaned it up and made a few modifications myself. But with a little imagination and some creativity, you could build something like this:
For a great example of how creative some people can be, follow this link!
ohtimberwolf
#4 posted 08-08-2013 01:34 AM
Wow,I never imagined anything like that was ever done. Those bases are a work of art. Thanks for all of this, it makes me want to get on to it. larry
View 69BBNova's profile
69BBNova
341 posts in 2122 days
#5 posted 08-08-2013 06:44 PM
I built a base for a Reliant 14in band saw, the base is all 3/4” ply…
Its east to find its my only Blog, and I screwed up because I didn’t realize it was to be broken up into different parts…
ohtimberwolf
#6 posted 08-08-2013 07:53 PM
Thanks to both Brad and BB for the great posts. It really helps to see all of these. larry
