BOX TOP SEPERATION
Forum topic by JUC posted 08-05-2013 06:25 PM 1102 views 0 times favorited 10 replies Add to Favorites Watch
View JUC's profile
JUC
116 posts in 2010 days
08-05-2013 06:25 PM
Good day, I need some help with cutting the top of my box. I will use my table saw. My question is which blade do I use, a 24 tooth rip or a 80 tooth crosscut or some other blade.
Thanks for the help!!
Jeffrey
-- If no one will ever see it, all the more reason to make it right
10 replies so far
View DanBall's profile
DanBall
5 posts in 1970 days
#1 posted 08-05-2013 06:30 PM
I would go with the rip blade. That is, of course, provided your grain is running horizontally, or parallel to the top and bottom of the box.
-- http://knotheadscny.blogspot.com
View DrDirt's profile
DrDirt
4451 posts in 3862 days
#2 posted 08-05-2013 06:41 PM
wont matter because you will likely need to do a bit of sanding anyway.
However start on a short end and work your way around so that you are making a long cut last
Some will put a 1/8th shim at the top with a piece of masking tape – but that more depends on the shape of the box and how stable it is.
Though I tune the fence alignment – I always need to sand the box lid to remove a little ledge from one of the corners, as there will be a little spring to the box lid as you cut it free that can push you away from the fence just a smidge.
To Sand it all back flat I usually use doublestick tape on the sandpaperpaper on the wing of the table saw.
View JUC's profile
JUC
#3 posted 08-05-2013 06:51 PM
Thanks for the help. That’s what I was thinking, but always goog to doubble check whrn in doubt.
Jeffrey
View MisterBill's profile
MisterBill
411 posts in 2371 days
#4 posted 08-05-2013 10:58 PM
Another good tip (not mine) is to make your cut approximately 1/64” short of the full thickness of your box sides. This will eliminate the need for shims. After you have cut all four sides you can use a razor blade to cut through the remaining wood.
View gfadvm's profile
gfadvm
14940 posts in 2809 days
#5 posted 08-06-2013 01:20 AM
MisterBill’s technique is much safer and less likely to ruin your box than making full thickness cuts.
View longgone's profile
longgone
5688 posts in 3428 days
#6 posted 08-06-2013 01:26 AM
I have also used the same method as MisterBill..It is a time proven and accurate method. i also would put some tape where the outside cut will be to help avoid splintering.
View Jim Finn's profile
Jim Finn
2670 posts in 3041 days
#7 posted 08-06-2013 02:25 AM
I build a LOT of boxes and cut the tops off in my band saw.
-- No PHD just a DD214 Website> craftingcouple.com
View bannerpond1's profile
bannerpond1
397 posts in 2018 days
#8 posted 08-06-2013 10:46 PM
I cut mine like Mister Bill, too.
Then I put a full sheet of sandpaper on a table with doubleback tape. I sand all four edges of the box and the lid with a rotary motion of my hands. Works great and insures you don’t sand too much on one edge and make a gap when the lid is on.
Since boxes are generally half an inch or less in thickness, a good combo blade works as well as a rip blade.
-- --Dale Page
View crank49's profile
crank49
4032 posts in 3090 days
#9 posted 08-07-2013 02:58 AM
Another vote for Mister Bill’s method.
Especially if your saw does not have a riving knife.
View JUC's profile
JUC
#10 posted 08-07-2013 10:22 PM
Thanks again for all the information!! Now I can not only cut a box lid off but I can be safe doing it.
Jeffrey
