Best material for making templates for routing?
Forum topic by Choupinette posted 08-04-2013 10:47 PM 5891 views 0 times favorited 11 replies Add to Favorites Watch
View Choupinette's profile
Choupinette
22 posts in 1768 days
08-04-2013 10:47 PM
Topic tags/keywords: question router template
Hi, I’m a newbie and I want to use a router to shape small pieces of wood / plywood with templates. What is the best material for this? I suppose it has to be hard enough so that the ball bearings don’t end up digging in it and damaging it.
Would a “hard board” do it? Plywood OK? Hardwood necessary?
The kind of shape I’m after looks like this:
Thank you!
-- Christine G., Northern California
11 replies so far
View Howie's profile
Howie
2656 posts in 2921 days
#1 posted 08-04-2013 10:50 PM
I usually use 1/4” hardboard. That way the bearing can ride on it.
-- Life is good.
Shawn Masterson
1325 posts in 1947 days
#2 posted 08-04-2013 10:56 PM
I use a lot of 1/4” underlayment. I pick it up free on site after the flooring guys get done.
View bondogaposis's profile
bondogaposis
4727 posts in 2350 days
#3 posted 08-04-2013 10:57 PM
I use 1/4” MDF.
-- Bondo Gaposis
View waho6o9's profile
waho6o9
8190 posts in 2575 days
#4 posted 08-04-2013 11:17 PM
MDF is good as is Baltic Birch 1/2 inch plywood.
View RGtools's profile
RGtools
3372 posts in 2653 days
#5 posted 08-04-2013 11:23 PM
I remember hearing about one guy using cheap plastic cutting boards. But that was to hold up to the abuse of making hundreds of a particular pattern.
-- Make furniture that lasts as long as the tree - Ryan
View rickf16's profile
rickf16
390 posts in 3579 days
#6 posted 08-04-2013 11:35 PM
1/4 or even 1/2 MDF. Cheap and pretty durable. I still have the templates for the craft center I made for my wife.
Keep us posted.
-- Rick
View newwoodbutcher's profile
newwoodbutcher
740 posts in 2848 days
#7 posted 08-04-2013 11:56 PM
I use 1/2” MDF
-- Ken
Choupinette
#8 posted 08-05-2013 12:17 AM
Wonderful, thank you. I think I’ll try a few, like MDF and plywood. I’m intrigued by the plastic cutting board idea. As for the underlayment, I’ll see if they have some avail. at the Habitat Restore.
Lots of experimenting ahead, I like it!
10394 posts in 3646 days
#9 posted 08-05-2013 01:17 AM
I use 1/4” hardboard usually for a throw-away type template.
The 1/4” thickness is easy to fair curves on with files. Go
to wider templates and fairing the curves is more work.
If you need durability for a production template, a good
quality veneer-core ply holds up well.
View NiteWalker's profile
NiteWalker
2737 posts in 2575 days
#10 posted 08-05-2013 01:37 AM
MDF for throw away templates, baltic birch plywood for my permanents.
Never an issue.
View shampeon's profile
shampeon
1775 posts in 2182 days
#11 posted 08-05-2013 04:31 AM
Yeah, use hardboard or quality plywood for the master, then make an MDF working template. Use the master once to make a working template, then use the working template to create any additional ones.
I’ve had master templates laser cut from melamine, too, and they’re great.
