Pattern Matching with mixed wood types
Forum topic by Gittyup posted 08-04-2013 11:42 AM 915 views 0 times favorited 2 replies Add to Favorites Watch
View Gittyup's profile
Gittyup
147 posts in 1982 days
08-04-2013 11:42 AM
I’m trying to make a cutting board that is a replica of the Maryland state flag.
Flag below
The cross is the problem. How do I best cut contrasting wood colors to produce the cross with a near seamless fit? I’ve try scroll sawing two pieces taped together. The pieces just are not identical enough to swap part between the woods without large gaps.
Appreciate any help.
Tom
-- tel
2 replies so far
Shawn Masterson
1325 posts in 1974 days
#1 posted 08-06-2013 01:31 AM
I would make a routable template. scroll it close then use the template to route it perfect
Gittyup
#2 posted 08-06-2013 01:57 AM
Thanks Shawn. What about the sharp corners? I haven’t seen template blades smaller than 1/4” that is still pretty coarse for the inside corners. Maybe hand cut the inside corners with a coping saw?
-- tel
