Apple wood??????????
Forum topic by Shawn Masterson posted 08-03-2013 12:17 PM 2200 views 0 times favorited 19 replies Add to Favorites Watch
Shawn Masterson
1324 posts in 1882 days
08-03-2013 12:17 PM
I have a neighbor that has an apple tree that is slowly coming down. is the wood good for anything??? I could have it sliced or turn it.
19 replies so far
15249 posts in 2552 days
#1 posted 08-03-2013 12:25 PM
Saw handles are typically apple wood.
View JustJoe's profile
1554 posts in 1972 days
#2 posted 08-03-2013 12:26 PM
+1 on saw handles. It’s a hard wood to find in decent sizes.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View Picklehead's profile
1041 posts in 1863 days
#3 posted 08-03-2013 12:39 PM
It’s GREAT for smoking chicken, pork shoulder, ribs, etc. (You said anything!)
-- You've got to be smarter than the tree.
View dhazelton's profile
2722 posts in 2230 days
#4 posted 08-03-2013 12:47 PM
I would save some turning blanks.
View Don W's profile
Don W
18662 posts in 2501 days
#5 posted 08-03-2013 01:00 PM
if its in good enough shape and big enough to actually get lumber (bigger than saw tote sizes) it makes for nice lumber.
-- - Collecting is an investment in the past, and the future.
View redSLED's profile
790 posts in 1826 days
#6 posted 08-03-2013 01:31 PM
Your next project. Make 12 and put them in a bowl.
2694 posts in 1958 days
#7 posted 08-04-2013 05:28 AM
Many years ago I made stropped blocks, for the mainsheet on my old sailboat, out of well-seasoned apple wood—two singles and one double. One of the singles had a becket. I first roughed out the shape, including the slot for the sheaves (bronze sheaves with bronze roller bearings), then boiled the shells in a mixture of linseed oil and turpentine for about an hour. (Extremely dangerous—don’t do this at home!!!). The heat distorted the wood, so I had to do some re rasping and filing. I filed grooves around, top to bottom, for the strops, which consisted of some old WWII navy surplus 3/8” manila treated with Stockholm tar (I still have a hank of that stuff—love the smell), which I laid up into grommets. I then seized the strops around bronze thimbles with tarred marline. Those blocks were out in all kinds of weather year round for at least 15 years, and always stayed their original very dark, almost black color. They were still on the boat after 18 years of owning it. Seems like I remember redoing the seizings after about 10 years. The only metal in those blocks (besides the sheaves and bearings) was the axle pin.
Wooden boat builders like apple wood natural crooks for quarter knees, and crotches for breast hooks. I always cringe when I see old worn-out apple orchards being bulldozed into gullies or burn piles to make room for new plantings (or worse yet, for mini-malls and subdivisions).
I realize this hardly addresses your question, but I enjoyed the opportunity to reminisce.
View bold1's profile
292 posts in 1781 days
#8 posted 08-04-2013 02:10 PM
On a circular sawmill the guide pins (they rub against both sides of the blade as it turns) were made out of apple if it was available, as they last longer than other common hardwoods from the USA. I understand it makes great slide blocks and work table surfaces.
View oldretiredjim's profile
206 posts in 2319 days
#9 posted 08-04-2013 03:03 PM
Agree with pickle – smoking.
View KTC's profile
3 posts in 1623 days
#10 posted 10-10-2013 03:10 AM
View poopiekat's profile
4335 posts in 3668 days
#11 posted 10-10-2013 04:15 PM
I just got some short sections of apple log, from an old tree that couldn’t even bear the weight of its own fruit, one good windy rainstorm, and it came down. These logs are approx 16” long by 8” or 10” in diameter. I had to put them in my truck and park it at the street, that foul smell of wet apple wood was nauseating!
would this be a decent wood for plane totes, should I turn it, or resaw some lumber out of them?
View uffitze's profile
199 posts in 2888 days
#12 posted 10-10-2013 04:31 PM
Apple is a beautiful wood. Bigger trees can be sawn into dimensional lumber that often has very nice figure. Color is red-tan with some lighter colored streaks. It is prone to checking and twisting though, so weigh it down when you sticker and dry it. It will also make very nice turning wood.
Some years ago, I managed to obtain some apple lumber from a tree that was 20” in diameter. I air dried it, and am just starting to roll it out into furniture. Extremely nice wood to work and it does have nice figure.
View Tim's profile
3758 posts in 1895 days
#13 posted 10-10-2013 06:15 PM
“would this be a decent wood for plane totes, should I turn it, or resaw some lumber out of them?”
Don’t know about turning, but yes to the others. I’ve been searching high and low for some decently wide apple for saw totes. Like uffitze said, apple wants to cup and warp like nobody’s business when it dries, so cut it thicker than you’d think and get some crazy amounts of weight on it when you sticker it and consider ratcheting straps if you have them. Or just take the bark off, seal the ends very well, and store the logs away somewhere to dry and come back to it several years later.
View TerryDowning's profile
1076 posts in 2051 days
#14 posted 10-10-2013 06:54 PM
Any wood that doesn’t fly apart is good for turning. Which means almost all of it. Some may need to be stabilized if rotting or weak.
-- - Terry
Shawn Masterson
#15 posted 10-11-2013 02:55 AM
I am going to show my ignorance here and ask what’s a “plane tote”?? I am 31 and work with power tools, I love “ole Iron” the bigger the better. I like my machines in the 500+ LB range.
