Bearings for G0490 jointer?
Forum topic by Marcus posted 08-03-2013 10:00 AM 1433 views 0 times favorited 10 replies Add to Favorites Watch
View Marcus's profile
Marcus
1163 posts in 2020 days
08-03-2013 10:00 AM
So I was hoping to track down some bearings for the grizzly g0490 jointer this weekend, but grizzly tech support is closed. It looks like they’re 42×20x12 bearings, but does anyone know if grizzly recommends anything specific?
10 replies so far
View Knothead62's profile
Knothead62
2584 posts in 2962 days
#1 posted 08-03-2013 10:30 AM
Good luck! I would wait until Grizzly opens up Monday AM. That way you should get an exact match.
View bowedstraight's profile
bowedstraight
100 posts in 1773 days
#2 posted 08-03-2013 03:21 PM
go to your local fastenal they have all bearings you need or any industrial supply company you can upgrade to a better bearing also that’s what I done on my tablesaw , my tablesaw size was 12mm x17mm x40mm, just look up the size and you should have no problem finding a bearing lot’s of places carry metric size bearings even autozone pepboys just about anywhere good luck I would definitely upgrade to a better bearing skf or something like that
-- Work in the city woodshop in tha country
bowedstraight
#3 posted 08-03-2013 03:24 PM
if they are 42×12 x 20 you should have no problem picking up bearings local and they should be a better brand if you go ceramic you might pay 40 $ a set or higher ceramic is the way to go if you want to put the money in them but they are expensive that would be the best upgrade
bowedstraight
#4 posted 08-03-2013 03:25 PM
grizzly bearings are ok but I would upgraDE to a better bearing just sayin
bowedstraight
#5 posted 08-03-2013 03:26 PM
I put neichi bearings in my tablesaw I think they own skf now but Im not sure
Marcus
#6 posted 08-03-2013 03:29 PM
I tracked down the size in the parts manual. It actually looks like two different sizes, 42×20x12 and 47×25x12…so odd. Looks like both fastenal and grainger are open mon-fri, I suppose I’ll give them a call then.
View MrUnix's profile
MrUnix
6716 posts in 2199 days
#7 posted 08-03-2013 08:01 PM
Those sound like common 6004 (42mm w/20mm bore, 12mm wide) and 6005 (47mm w/25mm bore, 12mm wide) bearings that you should have no problem finding. I would however pull the old ones first before buying the new ones.. just so you can make sure the bearings that are in there are the ones specified in the parts manual. I have seen on more than one occasion where the paperwork showed one thing and it turned out to be something different once opened up!
Marcus
#8 posted 08-03-2013 08:26 PM
Hah, good timing brad. I just got up from the basement and taking the jointer apart. It’s definitely a 6004 bearing. I can’t find my little clip remover to verify the other.
bowedstraight
#9 posted 08-03-2013 08:54 PM
yes 6004 is the # I have 4 extra but I fergot whered I puuttem but thats me hell I forgot my dam facebook ID and ething else but I have those bearings somewhere maybe I put them in my golf bag, anyway those new bearings will make it purr like a tiger make some dust and have a good day
View Bob Kassmeyer's profile
Bob Kassmeyer
223 posts in 2926 days
#10 posted 08-04-2013 01:35 AM
Grizzly lists the generic bearing numbers they are BALL BEARING 6005-2RS, BALL BEARING 6004-2RS. You can order these from any of the online bearing distributors. I bought some when I changed to a helical head. I can’t remember right now who I used but they were less then 15 dollars with deliver.
-- Bob Kassmeyer, Nebraska
