need some ideas
Forum topic by lance posted 388 days ago 200 views 0 times favorited 12 replies Add to Favorites Watch
View lance's profile
lance
168 posts in 887 days
388 days ago
Topic tags/keywords: question
my kitchen wall cabinets are built, stained and polyed and so are the faces. Went to drill the pocket screw holes on the inside of the cabinet sides that will show and realized my drill machine and the bit are to long to fit inside the cabinets. Any suggestions for getting around this dilemma? Oh! My right angle attachment wont do the job either. Your help will be greatly appreciated. Have a great day.
-- Bob Lance, DE
View lew's profile
lew
4509 posts in 655 days
388 days ago
There is an adjustable right angle drill attachment. the angle can be varied from less than 45 to 90 degrees. I can’t recall the name but I have seen them at Lowes.
lance
388 days ago
Thanks. I have the 90 deg version, but the grip still gets in the way.
-- Bob Lance, DE
View itsme_timd's profile
itsme_timd
676 posts in 730 days
388 days ago
Bob,
What about one of those flexible shaft drill extensions? LJ’s store has quite a few listed – here.
Tim
-- Tim D. - Woodstock, GA
View Damian Penney's profile
Damian Penney
1030 posts in 890 days
388 days ago
Epoxy the sides on instead :)
View OutPutter's profile
OutPutter
321 posts in 890 days
388 days ago
Bob,
What if you drill the pocket hole at 45 degrees pointing up to the top of the cabinet or some other angle so that the drill fits?
Is it close enough that a smaller drill would help (bet you didn’t think of that)? ;2)
-- Jim
lance
388 days ago
Tim and Damian, two good ideas that I will give real consideration and let you guys know what solution I finally put to use.
Thanks and have a great day
-- Bob Lance, DE
dennis mitchell
3791 posts in 1214 days
387 days ago
Duct tape!
You can just glue and clamp the face frames. They just have to sit in the clamps for an hour or so. (Great reason to buy more clamps!)
View Kindlingmaker's profile
Kindlingmaker
1479 posts in 426 days
387 days ago
Maybe the hard way… measure and back drill… then use a small ratchet, socket with bit the drive home the screws. I am a professional in getting myself backed into a corner!
Kindlingmaker
387 days ago
Oh I jusr remembered… I once used a ratchet with a hex base drill bit to hand drill a hole. Its a pain but I got it done.
lance
372 days ago
Hi Everyone,
Thanks for all the tips. I ended up borrowing a shorter pocket hole drill and a smaller 90 deg. drill attachment that allowed me to use pocket screws. Then I had to buy a Bosch PS10 adjustable 90 deg. power driver to screw in the pocket screws.
Happy Holidays to All
-- Bob Lance, DE
View Peter O's profile
Peter O
1027 posts in 774 days
372 days ago
Glad you found a solution that works for you. In case anyone else is having a similar problem, you could try glue and dowels or biscuits.
-- http://www.north40custom.com -- http://north40studios.etsy.com --
lance
372 days ago
Thanks again. I passed on the biscuits because the would had already been stained and sealed.
Happy Holidays
-- Bob Lance, DE
