oak pedestal for table
« back to Joinery forum
Forum topic by ewinger posted 07-31-2013 08:30 PM 1190 views 0 times favorited 4 replies Add to Favorites Watch
View ewinger's profile
ewinger
21 posts in 2023 days
07-31-2013 08:30 PM
I will be the first to admit I am not good at geometry
My wife wants to convert a coffee table back to a dinning room table and I need to built a 8-sided pedestal to do this and I cannot come up with the angular to cut the piece to make the octagon ship come someone help
Bill Ewinger
Burlington Iowa
-- Bill ewinger
View Mark Kornell's profile
Mark Kornell
1169 posts in 2497 days
#1 posted 07-31-2013 09:01 PM
An octagon has 8 sides, so 360 degrees divided by 8 = 45. Since each side of the joint uses half the angle, 45 / 2 = 22.5. So, tilt your saw blade at 22.5 degrees from vertical.
-- Mark Kornell, Kornell Wood Design
View DS's profile
DS
2894 posts in 2386 days
#2 posted 07-31-2013 10:07 PM
Check! Mark’s got it!
22.5 degrees. A router bit can also do the trick. They make one with 22.5 degree angle just for this purpose.
View RogerInColorado's profile
RogerInColorado
321 posts in 1920 days
#3 posted 08-02-2013 05:41 AM
I’ve done exactly what you are getting ready to do. The cut down table was my Mom’s, one of my sons wanted it as a dining table. The math above is right. I’d recommend building a prototype out of MDF or plywood to make absolutely certain your angle set up is dead on and that you have a good glue up strategy. I used the packing tape method and got perfect results, but it takes a little practice with 8 sides to get the pedestal dead square.
View rrww's profile
rrww
263 posts in 2079 days
#4 posted 08-02-2013 02:14 PM
We do around 1000 octagons a year, its real easy. Make sure wood is flat / square before you start. One bad piece will throw off the whole pedestal. Get a tiltbox or wixey and your miters will be perfect. Band clamps are the way to go for clamping!
Good Luck
