Crack in Cherry
Forum topic by sphayden posted 07-31-2013 01:54 AM 1012 views 0 times favorited 6 replies Add to Favorites Watch
View sphayden's profile
sphayden
38 posts in 2198 days
07-31-2013 01:54 AM
I’m building a cherry bed and cutting the headboard parts now. This cherry board I got has a crack. I filled it with epoxy, as well as the knot next to it. I don’t really like it. I don’t think it will make it into my project. Was that the right way to fill it, or is the crack just too big?
View PurpLev's profile
PurpLev
8534 posts in 3558 days
#1 posted 07-31-2013 02:00 AM
I personally thiknk that’s a big crack. if it’s for a part that will not be visible- that’s an OK fix, but for a headboard piece, I’d put it aside for a future project where you can work around it, and use a clean board for the headboard (lots of boards in this sentence)...
View lumberjoe's profile
lumberjoe
2894 posts in 2158 days
#2 posted 07-31-2013 02:17 AM
I’m not sure how well this will work for you, but I’ve fixed some cracks with the following method:
- Get some medium CA
- Get a good pool on top of the crack
- Get a shop vac and put it underneath
- Keep adding some CA until it stops sucking through
- Clamp it HARD
- Let it sit overnight
- No more crack
View kajunkraft's profile
kajunkraft
148 posts in 2119 days
#3 posted 07-31-2013 02:34 AM
I’ve used the vacuum fix with CA glue and it really does work. However there is probably a better use for this piece somewhere else or some other project. Between the crack & the knot, it’s not worth the trouble.
View RussellAP's profile
RussellAP
3103 posts in 2196 days
#4 posted 07-31-2013 04:48 AM
I see things like this as an opportunity to do inlays from turquoise, or malechite, or anything you like really.
View Nomad62's profile
Nomad62
726 posts in 2867 days
#5 posted 08-01-2013 11:04 PM
With all the figure and bark inclusions I’d recommend saving it for another project as well; it’s too likely (opinion, of course) to continue cracking, even in another direction; and, solidifying this point may stress another into cracking. Nice wood, you’ll get a good use for it.
sphayden
#6 posted 08-04-2013 01:38 PM
Yeah, I’m not going to use it for this one. Cherry is expensive, I’ll definitely use it in another project.
