Tongue then Groove or Groove then Tongue?
« back to Joinery forum
Forum topic by KevinBlair posted 07-30-2013 09:22 PM 1891 views 0 times favorited 12 replies Add to Favorites Watch
View KevinBlair's profile
KevinBlair
56 posts in 2227 days
07-30-2013 09:22 PM
Topic tags/keywords: question
I am getting ready to make 18 cabinet doors for the kitchen cabinets that I have been steadily making for the last several months.
The doors will be “shaker style” using birch hardwood (1/4” Baltic birch plywood for the panels) with tongue and groove joinery and a flat panel (my wife likes the IKEA cabinet look and that is what I am emulating).
I have decided to make the T&G using a router table and a T&G bit set.
My plan had been to mill all of the wood to thickness and width on my planer, jointer, and table saw and to start on the joinery by cutting all of the grooves needed (probably make 10-15% more linear feet than I measure as needed), cut my stiles from the grooved wood, and then make the rails (i.e., tongues).
However this video: http://www.youtube.com/watch?v=xNJP0Vw9EMY, showing the making of the kind of door I want, is pretty firm in saying that you should make the tongue first, then the groove. I have looked for other videos showing best technique, but this is the only one I’ve found (if you know of others, please post the link).
I can do it as shown in the video and I understand the logic of fitting the groove to the tongue as demonstrated in the video, but it seems less efficient than running all of the grooves first. Of course, if getting the tongue to fit the cut grooves is too difficult, then this would be the better, more efficient, way.
So, should I make the tongues first and then the grooves (as shown in the video) or will I be better to make all of the grooves and then make the tongues? I could also make each door separately (i.e, one at a time), but that seems really inefficient and may also lead to noticeable variations in the doors.
Thoughts and ideas welcome!
Kevin
12 replies so far
View Gene Howe's profile
Gene Howe
10108 posts in 3330 days
#1 posted 07-30-2013 09:27 PM
Most tongue and groove router bit set sellers will have a set up block for sale. A few bucks but worth it. Alternatively, you can make your own when you have it set perfectly.
Then, it wouldn’t matter which you do first.
View TheDane's profile
TheDane
5364 posts in 3565 days
#2 posted 07-30-2013 09:45 PM
Kevin—Gene is right … a few bucks for a setup block that matches your cutters is a wise investment. FWIW, I have done a few projects with T&G, and have always cut the grooves first. My T&G bits came from MLCS.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1974 days
#3 posted 07-30-2013 09:46 PM
We make about 2000 doors a year, and we always run the grove first. cut, then set up the coping set up to the grove. Running LF of the material is more efficient and with proper set up more consistent. good luck.
-- Who is John Galt?
joeyinsouthaustin
#4 posted 07-30-2013 09:51 PM
it seems his selling point is the fact that the push stick he is using becomes the alignment block for the stick. The opposite is true once you have a the material “sticked” in bulk (we call it cope and stick in our shop) just cut a test piece to set the coping set. same thing in reverse. Since we cope in a sled, we would not have the push stick to work off of, and such.
17517 posts in 1758 days
#5 posted 07-30-2013 10:24 PM
With my rail and stile set I run the stile ends first and then change to the other bit. This way you can remove tear out that may occur when cutting across the grain. When you make the groove it removes the end where the tear out was.
View Charlie's profile
Charlie
1100 posts in 2188 days
#6 posted 07-30-2013 11:01 PM
I made mine on the table saw. Shaker rails and stiles don’t have anything to really cope. It’s all straight edges.
Painted, but the top doors haven’t been painted yet.
Inside of one of the painted doors.
Small tongues. Only 3/8, but they’re holding up just fine. Thank you titebond III
The upper doors are small, but have removable panels. In case she decides she wants glass or just a decorative panel insert for holidays, etc…
Grooved everything on table saw.
Cut stiles to length.
Cut rails 3/4 over.
Cut tongues using Osborne EB-3 and my dado set on the table saw.
Rabbeted the backs of the plywood panels so the fronts are inset and the backs are flush.
Done deal.
View theoldfart's profile
theoldfart
9409 posts in 2353 days
#7 posted 07-30-2013 11:27 PM
Kevin, I’m a hand tool guy however the advice given above about doing all the grooves first is sound. I use a combination hand plane and will groove all my stock first, then crosscut to length. Then set up my tongue cutter and do all of that stock next, and cut to length. You’ll get better consistency this way. Good luck
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
KevinBlair
#8 posted 07-31-2013 03:35 PM
Thanks everyone! I will run the groove and then do the tongues. Hopefully this weekend or early next week. I will try to post some pictures and some info on how things go.
Kevin
Rick Dennington
5685 posts in 3096 days
#9 posted 07-31-2013 04:39 PM
I also run my tongue and grooves on the table saw…..I have a t&g set for the router table, but I’ve just always did them on the table saw…...I have a set up I built especially for them in jig form…..Works for me….
-- " Don't pet the sweaty things, and don't sweat the petty things."
View cutmantom's profile
cutmantom
401 posts in 2936 days
#10 posted 07-31-2013 04:54 PM
use scrap and try it both ways to see which is better for you
View RogerM's profile
RogerM
790 posts in 2301 days
#11 posted 08-01-2013 04:03 PM
Kevin – You probably should check out the Sommerfields Own tongue and grove cabinet system. I have used this for a number of years with a lot of success. http://sommerfeldtools.com/
-- Roger M, Aiken, SC
View Fuzzy's profile
Fuzzy
297 posts in 3890 days
#12 posted 08-12-2013 09:34 PM
I too have been using the T & G Cabinet System for years … in fact, I have one of the first sets sold by Sommerfeld … they were made by CMT .. before he went Chinese on us. I use them a lot, and while they COULD be adjusted for making cabinet doors, that really isn’t their strong point or intended use.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
