Help identifying Hand Drill
« back to Hand Tools forum
Forum topic by jasondain posted 07-30-2013 02:57 PM 2855 views 0 times favorited 13 replies Add to Favorites Watch
View jasondain's profile
jasondain
50 posts in 2889 days
07-30-2013 02:57 PM
Topic tags/keywords: question drill eggbeater
I picked up this eggbeater drill for a few bucks while there and have been trying to research its lineage on different websites. I’ve come close to hitting the mark a few times but this one seems odd. I think it is a Millers Falls (#1 or #105) or at least Goodell Pratt but not sure.
Unfortunately, several parts look to have been replaced by the former owner(s) including the crank handle so the only distinguishing mark is a D cast into the crank. It has some sort of crank tensioner/adjustment screw that adjusts to rub against the crank wheel to keep it steady as opposed other styles I’ve seen online. Also, the handle was mounted via a 5/16 steel rod driven into the frame as opposed to having it cast and then threaded like some others I’ve read about.
Any help identifying this would be appreciated.
13 replies so far
View Don W's profile
Don W
19007 posts in 2766 days
#1 posted 07-31-2013 07:36 PM
I can’t be of much help, but will say the answers to these questions often comes when they are most unexpected.
View WayneC's profile
WayneC
13783 posts in 4296 days
#2 posted 07-31-2013 07:44 PM
Looks like a quality tool.
View theoldfart's profile
theoldfart
10164 posts in 2650 days
#3 posted 07-31-2013 07:57 PM
I’m not seeing anything like it on either MF nor GP web pages. Maybe a pic or two of the tension device. Also have you gone over the chuck real well looking for clues there? The chuck design may help define who made it. Both GP and MF checks are well documented.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View PurpLev's profile
PurpLev
8547 posts in 3847 days
#4 posted 07-31-2013 08:12 PM
could be a craftsman or the likes too. I think I have a CM. I’ll see if I can get any ID’s off of it when I get home
jasondain
#5 posted 07-31-2013 09:04 PM
The chuck has no marks on it but has 3 jaws and will fit bits smaller than 1/4”. There are no springs on the chuck and it threads onto the spindle to tight the jaws. See pic.
The Tension device is two screws, one that protrudes through the frame and the other to tighten it in place. The screw rubs on the back of the wheel to keep it from getting tilted by the crank pressure.
Thanks for your help!
theoldfart
#6 posted 07-31-2013 10:19 PM
Jason, it is a Millers Falls. Look at this:
http://oldtoolheaven.com/hand_drills/drillimg/Equalizerbring.jpg
Having trouble with the frame, it looks like a No. 02, but the tension adjustment and chuck are from a No.1
Have a look here:
http://oldtoolheaven.com/hand_drills/drill1.htm
Hope this helps
jasondain
#7 posted 07-31-2013 11:01 PM
That’s what I figured as well but I couldn’t find anything where it had this frame shape and the Equalizer like mine has. In any case it is really nice and I am going to recondition it including turning some new handles, making ferrules and re-painting etc.
Thanks for your help. I’ll post pics when done.
View Waterlog's profile
Waterlog
106 posts in 2131 days
#8 posted 06-08-2015 10:16 PM
Here is an eggbeater drill I picked this weekend. It looks quality made but I can’t ID it. Can anyone please .give me a clue?
The partial decal fell off since Saturday but the handle is marked Made In The USA, A1.
Thanks in advance. Lester
-- LWB Waterlog
theoldfart
#9 posted 06-08-2015 10:45 PM
Dunlap I think.
Waterlog
#10 posted 06-09-2015 01:22 AM
Thanks Kevin, I will see what I can find. LWB
Yup! That’s it, Dunlap. Doesn’t look like they are bringing much on eBay. I have sold at least a dozen MF hand drills on eBay. Usually I don’t go for the solid gear wheel type but it looked solid and the fit and finish was good and all the handles are here. Anyway, thanks again. BTW that was a good haul you got this week picking. I had a good day of it Saturday.
-- LWB Waterlog
theoldfart
#11 posted 06-09-2015 01:39 AM
Lester, looks like you were pickin and a grinnin!
View danielperry770's profile
danielperry770
2 posts in 292 days
#12 posted 02-27-2018 01:31 AM
Any advice on this one it is missing the proper handle I believe.
View BlasterStumps's profile
BlasterStumps
975 posts in 638 days
#13 posted 02-27-2018 03:57 AM
Say Waterlog, any chance you could share some pictures of the wooden plane with the skewed blade?
Mike
Yup! That s it, Dunlap. Doesn t look like they are bringing much on eBay. I have sold at least a dozen MF hand drills on eBay. Usually I don t go for the solid gear wheel type but it looked solid and the fit and finish was good and all the handles are here. Anyway, thanks again. BTW that was a good haul you got this week picking. I had a good day of it Saturday.
- Waterlog
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
