Staining help
Forum topic by FrogpondWoodworks posted 07-30-2013 01:35 PM 1421 views 0 times favorited 6 replies Add to Favorites Watch
View FrogpondWoodworks's profile
FrogpondWoodworks
39 posts in 1688 days
07-30-2013 01:35 PM
Topic tags/keywords: finishing staining stain question ash oak
I have no finishing experience except what I’m working on right now. So as to staining wood. Does/should the wood get darker with more coats? Using Minwax to match a piece of flooring to existing hardwood flooring. Took sample pieces to the store and got a couple of small cans that matched the closest but when I stained my sample piece none of the stains really come close to matching. The wood is white oak, sanded and scraped.
So far I’ve used Dark Walnut, Ebony(accent pieces around the door), and Ipswitch Pine. My hardwood floor was titled Gunstock in Ash wood. Thinking of mixing the Dark Walnut and Ipswitch Pine together and trying that next.
And do I need to sand between stain coats? I’ll try to post pictures of my test piece when I get back home.
-- Rich, Kentucky
View Clint Searl's profile
Clint Searl
1533 posts in 2231 days
#1 posted 07-30-2013 01:52 PM
Just mix and match until you get the desired shade. Try ZAR brand; it’s better than MinWax.
View fredj's profile
fredj
186 posts in 1688 days
#2 posted 07-30-2013 01:56 PM
You don’t need or want to sand between coats of stain. More coats will make it darker, up to a point.
Good luck
-- Fredj
View Hammerthumb's profile
Hammerthumb
2809 posts in 1845 days
#3 posted 07-30-2013 04:51 PM
I agree with Clint that the Zar brand is better than Minwax. Gunstock is one of the harder colors to match. I recommend taking a sample of the existing flooring to Sherwin Williams or another paint store that will mix stains for you. Make sure you take a sample of the existing flooring and a raw piece of wood that they can use to match the stain to. We have only one Sherwin Williams store in Las Vegas that will do that. I do not recommend putting 2 coats of stain down on flooring. The more stain that is applied, the greater the chance to have adhesion problems with the finish.
-- Paul, Las Vegas
View pintodeluxe's profile
pintodeluxe
5542 posts in 2683 days
#4 posted 07-30-2013 04:59 PM
Well, if you are trying to match stained ash, first and foremost start with ash.
Avoid Minwax stains – they are thin bodied stains high in dye content, and low in suspended solids. Choose a Rodda or Cabot oil based stain. Varathane brand is pretty good too.
Try to pick a color that hits the mark in one coat. Mix compatible stains to vary the color, and make a bunch of test boards. I have also had good luck tweaking stain colors with universal colorants like raw umber, and burnt umber available at any paint store. Sand the test boards just as you will the actual project, then stain. Let the test boards dry overnight, and then topcoat them with your intended finish. A finish looks different once the topcoat goes on.
Good luck.
View gfadvm's profile
gfadvm
14940 posts in 2560 days
#5 posted 07-31-2013 12:51 AM
MinWax makes a Gunstock stain that I really like on oak and it was a perfect match for some Gunstock stained flooring (but I may have just been lucky).
View Henry6's profile
Henry6
36 posts in 1897 days
#6 posted 11-19-2013 12:37 PM
Seeing as you are mixing stains, why not throw my favorite new brand into the conversation? Has anyone else used Storm System exterior products? It was recommended by a buddy because the products are differentiated by weather and traffic conditions, which I needed. I know they have color stains as well. Hope this helps and best of luck.
