Can anything be put over shellac?
Forum topic by natenaaron posted 07-30-2013 05:21 AM 6781 views 0 times favorited 30 replies Add to Favorites Watch
View natenaaron's profile
natenaaron
442 posts in 1826 days
07-30-2013 05:21 AM
So, I was not able to find Seal Coat anywhere in the next big town over. The tru-value here cannot order it, neither can the lumber store, so based on my previous snafu Poly is out. I know it will absorb blotchy.. Is there anything I can put over Shellac as a protective coat? Will an automotive clearcoat adhere to the shellac? I really want to get this project done. I go back to work Wednesday and would feel bad if this was another summer project left undone.
30 replies so far
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2383 days
#1 posted 07-30-2013 05:34 AM
I have seen lacquer work, but it was a professional grade of lacquer. You might try…. car wax.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View shampeon's profile
shampeon
1775 posts in 2212 days
#2 posted 07-30-2013 05:42 AM
Almost everything can go over shellac. Do a test panel and try it.
TCCcabinetmaker
#3 posted 07-30-2013 05:45 AM
eh, it’s usually best to stick to one type of finish to be honest, mixing certain chemicals can be risky. But like he said, make a test piece.
View tefinn's profile
tefinn
1222 posts in 2466 days
#4 posted 07-30-2013 05:59 AM
I use Deft and Minwax lacquer over shellac all the time. I also have used poly. It’s not recommended but it will work. Danish oil over 1/2 lb cut shellac is another that I use then top coat with poly or lacquer.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View Woodknack's profile
Woodknack
11827 posts in 2409 days
#5 posted 07-30-2013 06:56 AM
I don’t know what you are building but shellac is a finish coat and will provide protection. Unless it’s a dining table or maybe an end table, I’d just stick with shellac.
5002 posts in 2522 days
#6 posted 07-30-2013 10:58 AM
How about a non-poly varnish? It’s the polyurethane resins in those formulas that cause the adhesion problems, switching to a non-poly formula solves all that. You don’t even really need to scuff sand between coats with them unless it’s to smooth out the nibs. Try Sherwin Williams Fast Dry Oil Varnish (alkyd resin/linseed oil formula) or Pratt And Lambert 38 (alkyd resin/soya oil). I do agree with Rick that shellac is a good finish on it’s own; it’s underrated by most folks. But for things that have wear, a good varnish works well.
natenaaron
#7 posted 07-30-2013 05:26 PM
This is a coffee table so it will see some heavy use and propping up of feet. Shellac scratches too easy and was wanting something as a top protective layer. I thought anything would go on top of shellac but when my finish blew off the top, literally, I am now pretty gun shy.
I will look for varnish
View crank49's profile
crank49
4032 posts in 2999 days
#8 posted 07-30-2013 05:32 PM
+1 on anything can go over shellac.
Shellac is the original seal coat.
You can even cover Vaseline stains with shellac and then paint over it like it was never there.
View Hammerthumb's profile
Hammerthumb
2853 posts in 2004 days
#9 posted 07-30-2013 05:41 PM
I would assume it was regular shellac and not de-waxed that you had problems with, as almost anything can go over de-waxed shellac. I have also heard of woodworkers letting the waxed shellac sit undisturbed for a while and you will notice the wax settling to the bottom. The shellac can then be removed from the can leaving the wax at the bottom. You could then use this as the final coat of shellac prior to other finishes. There was another thread going round on LJs where someone asked if there had been any personal observations where poly did not adhere to a regular shellac surface. You might want to chime in on that thread to save the guy some problems. I have no experience with waxed shellac and non-poly varnish as stated by Fred Hargis, but do not see why this would not work. Try a test piece. Good luck!
-- Paul, Las Vegas
View ChuckV's profile
ChuckV
3124 posts in 3556 days
#10 posted 07-30-2013 05:47 PM
I think it is more correct that anything can go over dewaxed shellac. Seal Coat is the dewaxed stuff, which you were not able to find.
From the highly recommended book Understanding Wood Finishes by Bob Flexner:
The wax slightly reduces the transparency of the shellac on the wood. It also makes the shellac less water resistant, and it prevents good bonding when reactive and coalescing finishes (varnish, two-part finishes, and water base) are applied over shellac.
EDIT:
Paul beat me to this response. The method of dewaxing the shellac yourself that Paul refers to is also covered in Flexner’s book.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View Clint Searl's profile
Clint Searl
1533 posts in 2390 days
#11 posted 07-30-2013 05:55 PM
Your experience is yet another recurring example of the fallacy of starting every finishing project with shellac.
Do it right: strip it and finish with only waterborne poly floor finish. If it’s tough enough to walk on, it’s tough enough to put a coffee cup on.
#12 posted 07-30-2013 06:07 PM
Quote: I will look for varnish.
Nate, the polyurethane you used was/is varnish. Thanks to Norm, stupid finishing company marketing, and probably several other things many folks think of “poly” as a different finish than varnish. Varnish is a finish made by cooking a resin (normally one of polyurethane, urethane, alkyd, phenolic) with a drying oil (normally linseed oil, but can also be tung oil or soya oil, maybe some lesser known ones) and the result is varnish. So what most folks call “poly” is (maybe) more correctly varnish, just made with polyurethane resins. Some of the waterborne finishes are now being called “poly” as well, and they are actually just an acrylic waterborne finish like most others, with a dollop of polyurethane resins added. Whether shellac is dewaxed or not is only important if you plan to top coat with a poly finish…otherwise, pretty much all the other stuff will stick to it.
natenaaron
#13 posted 07-30-2013 06:19 PM
I prepped and sprayed the metal portions of the table with enamel clear coat. Will that work for the table top.
#14 posted 07-31-2013 11:32 AM
When you say “will it work”, without knowing a little more about exactly which one it is, I’d say it will stick (back to what I said about the urethane resins earlier). Whether it would look good and meet your criteria is your call.
View RogerM's profile
RogerM
792 posts in 2428 days
#15 posted 07-31-2013 02:03 PM
Seal Coat is nothing more than dewaxed shellac diluted with alcohol. Try mixing your own Seal Coat if you would still like to go that route. I have used it for a number of years with ecellent results. You can easily order Seal Coat from Rockler for around $15.50 a quart.
You do not indicate where you are located so not sure about your local suppliers. Both Loews and Home Depot stock Seal Coat.
-- Roger M, Aiken, SC
showing 1 through 15 of 30 replies
