Wood trim for doors in a wonky corner
Forum topic by Charlie posted 07-29-2013 01:43 PM 4752 views 0 times favorited 16 replies Add to Favorites Watch
View Charlie's profile
Charlie
1100 posts in 2527 days
07-29-2013 01:43 PM
Topic tags/keywords: question
I have 2 doors that “meet” in a corner. They don’t touch each other, but the hinge side of both doors is toward the corner. There is about 3 inches of wall from the hinge side jamb to the corner.
The problem I’m running into is that while the doors are plumb, the wall is not. On one of the doors, the jamb is inset about 1/8 to 3/16 at the bottom and slightly proud of the wall at the top by the same 1/8 to 3/16.
On the other door, also plumb, the top of the hinge side jamb is 3-1/4 from the corner and the bottom is 3 inches.
The trim will be painted but I’m not a trim carpenter and I’m wondering what you think might be the best way to trim out this corner. The latch side jambs are fine. This is a 1960 ranch so….. typical “not-everything-is-straight” situation.
16 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2279 days
#1 posted 07-29-2013 02:12 PM
How about having the trim go up the latch sides and all the way across the tops of both and meeting with a cmiter in the corner so as to make it look like both doors are part of one doorway. Then the strip in the middle there can be trimmed out with a flat-piece the same thickness as the bottom edge of the top trim, or slightly thinner. You can butt the two pieces (one for each wall) against each other and put a line of caulk down the edge. When you paint it that middle piece will then look like one solid stile.
EDIT: Forgot to mention – for a piece that small, just a few inches on each wall, there’s no reason for the wall to stick out/in 1/16”. Just take a hammer and block of wood, or a rasp, or a lot of sandpaper, and correct it before putting the trim on. You’ve got the thickness of the drywall to play with, and you can always slap some mudon the low spot before putting the trim on, so there’s no reason not to even it up. If the doors are plumb, when you are done that stile will look plumb too.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
Charlie
#2 posted 07-29-2013 03:01 PM
Oh, the trim across the top will meet in the corner as you talked about. The latch side trims will go from floor to the underside of the top trim. The top trim will stick out past the latch side trims about an inch.
It’s not just drywall. It’s the old gyp-board. Think drywall in planks. In that top photo, showing the bottom of the door, there’s wood there. I’d have to chisel off almost a quarter inch of wood, maybe an inch wide, before getting to the drywall and then shave the drywall down from the floor up to about 38 inches from the floor. That would mean a stop at Harbor Freight or something to pick up some crappy chisels as I wouldn’t want to do this with my good ones :) And…. it sounds like a real mess, BUT it might be the best to try to straighten the wall surface.
I need to trim these doors before I can do the baseboards. PITA. I love old houses….. sigh
JustJoe
#3 posted 07-29-2013 03:06 PM
Been there with cabinets and a way-out-of-whack soffit. It’s no fun. Instead of chiseling out, maybe buy one of these and a dust mask and just power through it:
http://www.harborfreight.com/3-1-4-quarter-inch-electric-planer-91062.html
Charlie
#4 posted 07-29-2013 06:44 PM
Well, here’s what I found through some experimentation…
I’m using leftover 6” tongue and groove pine boards. If I mill a dado, 3/16” deep and a half inch from the edge that will be against the hinges… I can make that dado 38 inches long and as wide as I need by making a few passes. Then I flip the board so it’s flat side down and trim it to width. Basically this “carves out” the clearance for the wonky wall at the bottom of that corner. The trim stays plumb as it’s following the hinge side jamb which is plumb.
I think I’m going to give this a try as it’s the least messy and least disruptive (to the kitchen) solution. If it doesn’t work, then I may have to bite the bullet and wreak havoc on the wall, but…. I’m going to give this a try.
View nailbanger2's profile
nailbanger2
1041 posts in 3385 days
#5 posted 07-29-2013 06:57 PM
That sounds like a good idea, Charlie. You may want to put a dado on all your trim pieces. Most manufacturers do, it aids in stability and leaves fewer gaps to be caulked.
-- Wish I were Norm's Nephew
View Loren's profile
10477 posts in 3889 days
#6 posted 07-29-2013 07:54 PM
Unless you want to mess with “backing out” the trim,
I recommend carving back the gypsum. Surforms
work.
404 - Not Found
2544 posts in 3210 days
#7 posted 07-29-2013 08:04 PM
Not a big deal to rebate the trim if you have an electric hand planer.
Charlie
#8 posted 07-29-2013 08:46 PM
Loren, it’s not just gypsum. If it was I’d shave it back or pull it out. It’s gypsum, wood, and probably some nail. Oh and the gyp is plastered. Not skim coated with joint compound… plastered. At this point I really can’t get much in there unless I uninstall the door which I’m not in a big hurry to do. It’s a tight corner.
Carving the back of the trim looks like it’s going to work. It only takes a few minutes to set the dado on the table saw and do a few passes. I know I should have addressed this when I was installing the doors, but to be honest, I was so darn frustrated with everything else at the time, I just didn’t remember to do anything with it.
I’m not real upset as it appears there are several ways to skin this cat. I just have to pick one :)
View JoeinGa's profile
JoeinGa
7740 posts in 2248 days
#9 posted 07-29-2013 09:12 PM
DUCT TAPE ... that stuff will fix (or cover up) most anything :-)
View widdle's profile
widdle
2069 posts in 3240 days
#10 posted 07-29-2013 09:16 PM
What the profile of the trim look like..What are it’s dimensions ?
Charlie
#11 posted 07-29-2013 09:21 PM
widdle, it’s plain. 3/4” thick, 3 inches wide for the side trims. 4 inches for the top trim. slightly radiused edges. It’s a cottage kitchen and the wife likes clean lines in some areas…door and window trim being one of them :) (or is that 2 of them?)
Baseboards will have a more ornate profile and will be 6 and a half inches tall.
widdle
#12 posted 07-29-2013 09:28 PM
So the legs butt the head peice ? is the head trim thicker.. And from the reveal to the corner is less than 3 to the corner ?
widdle
#13 posted 07-29-2013 09:43 PM
If it’s not too late i would cheat the doors out of plumb a bit…And try to get the the two hinge sides a little closer to the same number from inside corner to your jamb ….If you dont want to dig out the plaster, You could rip some 1/8” or whatever jamb extensions that will get you back out to flush…Or even better, tapered jamb extensions..as far as jamb extensions go , you can give them a reveal, and than step back again for the trim..
widdle
#14 posted 07-29-2013 09:45 PM
Or just go with tapered rabbetts
Shawn Masterson
1325 posts in 2190 days
#15 posted 07-30-2013 12:19 AM
first of all you either carve out the back or beat the rock/(plaster). beating the rock is very common practice. in most corners the taper will leave it out of square and flared out at the bottom. if you run the heads into the corner and put mulls (1/4”x whatever) for the legs it looks nice and clean. there are my place.
