Forum topic by boomfiziks | posted 07-29-2013 07:26 AM | 1302 views | 0 times favorited | 2 replies | ![]() |
I am familiar with the Roubo book stand cutting technique, where from a single board, you can create a hinged joint. The Roubo book stand goes from a “closed” position (0 degrees) to an “open” position (90 degrees). What I’m wondering, is there a similar cutting technique that can take a flat board and cut a hinge in the middle? In other words, can you cut a hinge that’ll allow it to go from an “open” position (180 degrees) to a closed position (90 degrees or less)? If so, is there a tutorial? Thanks, |
