Drill press parts
Forum topic by Leegustus posted 07-29-2013 07:25 AM 1034 views 0 times favorited 1 reply Add to Favorites Watch
View Leegustus's profile
Leegustus
3 posts in 2001 days
07-29-2013 07:25 AM
I have a Central Machinery drill press that I bought from Harbor Freight a few years ago. The model # is 38119. Well I needed to order a part so I called HF and sales rep said that the parts were no longer available through HF. I’ve searched the web for Central Machinery and they have done a very good job of hiding. Help! Thanx
1 reply so far
View IrreverentJack's profile
IrreverentJack
727 posts in 3079 days
#1 posted 07-29-2013 02:33 PM
Check for a similar/identical Jet or Grizzly model and get a part number (Grizzly customer service can very helpfull). Most of the Taiwanese stuff is similar in design and may even be made in the same factory. If you would mention the part you need you might get more specific help. I Googled a number off a broken switch from a DP like yours and found an identical Ryobi replacement part. Good luck. -Jack
