router jig for surfacing odd shaped wood slabs
Forum topic by millingman posted 387 days ago 1517 views 1 time favorited 9 replies Add to Favorites Watch
View millingman's profile
millingman
3 posts in 410 days
387 days ago
i have an idea for a jig to surface the top of large odd shaped wood that will not fit in my planner/sander. But i would like to see other jigs that some one else has made before I proceed with building mine. I am mainly going to use this jig for surfacing large slabs that come off my sawmill to make rustic furniture and benches.
-- www.tackettmillingandwoodworks.com
14932 posts in 748 days
387 days ago
Millingman, I will watch with interest. Most I have seen are very expensive. Have you searched the LJ’s site?, I seem to remember someone may have posted something.
View Loren's profile
347 posts in 545 days
387 days ago
Slow going to do it with a router.
The slab will move after every surfacing attempt, so I plan for that
if I want to flatten a big slab.
I use a 4” Makita hand planer, working crosswise and sighting
by eye to get one side flattish, flip it and do the other. Let it
sit and then it’s at least a couple more flattenings of each side.
Then I go to a belt sander and ROS after that.
I honestly think doing it with a router is way too slow – but I’ve
seen a couple of jigs that use a rail system. The Legacy ornamental
mill can be used to flatten slabs with a router but it’s tedious and
noisy.
If you wanted you could build a CNC machine and
walk away and let it do all the work – in that case you don’t have to
put up with all the noise and the slowness of the router process.
-- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html
millingman
3 posts in 410 days
387 days ago
loren: can you use a power planer on end grain as well? i have never used a power hand planer so i do not know its limitations. now i know that if you send a piece of end grain through a normal planner. you had better get down on your knees and prey to the wood gods that nothing happens. nine times out of ten it is going to make a real mess and damage to anything in and around the machine. i reall need something that can handle some end grain as well. my sawmill will cut the slabs fairly straight and flat but, after the slab dries it wll more than likely be cupped and i do not want to spend hours with a belt sander.
one day i would like to get a small cnc router but it really is not in my budget. I would like to get a 50” belt belt sander i know that would do the trick.
25803 posts in 1297 days
387 days ago
I’ve done something like this.
I had a couple of aluminum tubes that were part of my Incra TS3 Table saw fence. I mounted them on each side and then used a trough where the router fit and moved it back and forth to surface the workbench top.
It not hard, just dont take very much in depth as you go.
Mark DeCou in one of his postings has done somethink like this also.
View Steve2's profile
Steve2
48 posts in 468 days
387 days ago
One of the members of Canadianwoodworkingforum made one – see it there.
-- Regards, Steve2
386 days ago
end grain – yeah, within limits. Take light cuts and just be
careful. I haven’t had a power planer kick back on me much and
I’m not that concerned it will but be careful anyway with end
grain. Unsupported fibers will get munched by a planer so if the
wood is pithy or not dense enough it won’t work well on end
grain.
386 days ago
Have you seen GaryK’s blog
http://lumberjocks.com/topics/1992
View GaryK's profile
GaryK
9536 posts in 885 days
386 days ago
Grumpy – I was going to mention that!
millingman
3 posts in 410 days
385 days ago
Thanks for the link grumpy
garyk : that is a nice jig that is somthing like what i had in mind but about 10 ” wider and i was doing to use aluminum angle on one piece if 3/4” plywood but I see how yours is two pieces and i might change to that style.
thanks for everyone inut and keep them coming.
