G0715P Wiring Question
Forum topic by ZiggyZ posted 07-27-2013 08:53 PM 1724 views 0 times favorited 4 replies Add to Favorites Watch
View ZiggyZ's profile
ZiggyZ
65 posts in 2620 days
07-27-2013 08:53 PM
I recently moved into a rental house while I’m stationed in Virginia and the garage at the house only has 15 amp circuits. I have a Grizzly G0715P hybrid table saw that I have a NEMA 5-20 plug on as Grizzly recommends.
Question is, being that I do not have 20 amp circuits in the garage and would like to avoid any modifications to the house, can I install a 15 amp plug on the saw and use it? Grizzly claims the motor draws 16 amps at 110v however the wiring is 14 awg and I know 12 awg is required for 20 amp circuits while 14 is for 15.
Would this work or will I just be tripping breakers? Has anyone successfully done this? Thanks as always for any advice and enjoy the weekend!
View gtbuzz's profile
gtbuzz
427 posts in 2676 days
#1 posted 07-27-2013 09:00 PM
Honestly, I’d be very surprised if that would work w/o tripping the breaker. Someone correct me if I’m wrong, but I believe that normally breakers will trip around 80% of the rated amperage, so on a 15A circuit, you’re really only looking at about 13A of usable.
I had a G0715P briefly and I had quite a few problems with it tripping my 20A 110v circuits. Remember that whatever you do, don’t simply swap out that breaker for a 20A breaker.
Unfortunately, I think your only recourse here is to install an actual 20A circuit with 12ga wire. Hopefully the owner lets you do that.
View toolie's profile
toolie
2148 posts in 2863 days
#2 posted 07-27-2013 09:46 PM
+1 on buzz’s comments, with the following info.
depending on what is also on the circuit with the TS and operating while the TS starts up, a 15A breaker will probably trip. the motor ratings are usually full load amps, i.e., the amperage the motor would draw at full load, or when it is doing the most work spinning the blade. at start up, there’s a chance the saw would start without incident, even given the start up surge, provided there’s nothing else operating on that circuit. however, apply a load to the saw, like ripping a thick piece of hardwood with a 40 tooth blade, and the odds are very good that the breaker will trip.
ZiggyZ
#3 posted 08-04-2013 01:05 PM
Thanks for the replies!
I ended up giving it a try with a NEMA 5-15 plug and so far, so good. Saw starts right up and I’ve ripped 8/4 alder with it and havent tripped a break so far, even with me attempting some pretty forceful ripping speeds to see if it would.
View HassanMirza's profile
HassanMirza
57 posts in 1076 days
#4 posted 11-07-2016 03:32 PM
ZiggyZ,
I am in the same situation and would like to know how that worked out for you long term?
Thanks,
Hassan
-- Hassan Mirza
