Removing paint from small pin holes.
Forum topic by Eric Wuennecke posted 07-26-2013 09:17 AM 986 views 0 times favorited 8 replies Add to Favorites Watch
View Eric Wuennecke's profile
Eric Wuennecke
8 posts in 1645 days
07-26-2013 09:17 AM
Topic tags/keywords: question tip resource refurbishing finishing rustic sander
I landed this antique drafting table from a guy that just wanted it out of his attic. The top was covered in a rather thick layer of paint that is being sanded off but it’s leaving a lot of little holes where drawings used to be pinned down. I figure I have two options: leave it and hate it or find a way to pull it out. Any suggestions?
8 replies so far
View Bluepine38's profile
Bluepine38
3377 posts in 2954 days
#1 posted 07-26-2013 01:58 PM
Unless you want to have a top that is 1/2” thick, you might have to settle for the primitive rustic look. You
could glue a good layer of 1/2” plywood to the bottom, sand it down and then glue some matching edging
on the sides and use matching breadboard ends, a lot of work, but could be fun.
View IrreverentJack's profile
IrreverentJack
727 posts in 2712 days
#2 posted 07-26-2013 05:43 PM
I can see two options. 1) A pin sized drill bit and a lot of time. 2) Seal the top and wipe black or matching color paint into the holes, then sand it of the surface and finish. Good luck. -Jack
View distrbd's profile
distrbd
2252 posts in 2315 days
#3 posted 07-26-2013 05:49 PM
Jack has a great idea,seal it and wipe it ,you want to preserve the flatness since it’s a drafting table .
-- Ken from Ontario, Canada
Eric Wuennecke
#4 posted 07-27-2013 05:07 AM
I was hoping to have the rustic look anyway, just without the paint. I think sealing and wiping might be the way to go. Any recommendations on a sealer? About all I have at the moment is some Thompsons.
View bondogaposis's profile
bondogaposis
4523 posts in 2220 days
#5 posted 07-27-2013 12:40 PM
You could veneer the top.
-- Bondo Gaposis
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1941 days
#6 posted 07-27-2013 01:19 PM
I would appreciate the holes. I like those recommendations. They are the clue to the age and purpose of the piece. It would be like taken the mole off Cindy Crawford??
-- Who is John Galt?
IrreverentJack
#7 posted 07-27-2013 05:59 PM
OOPS. -Jack
IrreverentJack
#8 posted 07-27-2013 06:06 PM
Id use a thin coat of shellac to seal the top. Make sure the top is mounted in a way that allows the wood to expand and contract. I learned that lesson on a drawing table similar to yours. I improved on original and it bit me on the butt. -Jack
