craftsman auto switch question
Forum topic by Jason978 posted 07-26-2013 07:21 AM 1371 views 0 times favorited 1 reply Add to Favorites Watch
View Jason978's profile
Jason978
10 posts in 1712 days
07-26-2013 07:21 AM
does the vacuum turn on simultaneously with the saw or is there a slight delay to avoid drawing too much power at once?
If it does start simultaneously, has anyone had any problems with tripping breakers? thanks
1 reply so far
View toolie's profile
toolie
2101 posts in 2504 days
#1 posted 07-26-2013 10:22 AM
it starts simultaneously but delays accessory shut down to clear dust form collection lines. it’s a rugged little unit. i have one and it used to power my TS and a 20gal shop vac on the same circuit. but that’’s it’s critical weakness. one circuit.
i moved on to the ivac switch product. primary and slave tool activation on two different circuits. provides greater flexibility:
http://www.ivacswitch.com/index.action
both the products and the people behind them are absolutely first rate. here’s my set up:
