Flattening question
Forum topic by Shane posted 07-25-2013 03:39 PM 849 views 0 times favorited 8 replies Add to Favorites Watch
View Shane's profile
294 posts in 1744 days
07-25-2013 03:39 PM
My most recent end grain board developed a twist from the final glue up. I don’t have a thickness planer (yet) and I’m not sure how to correct the twist. Any thoughts? My best guess is to put feet on one side that are at different heights to hide the twist and then make it a one sided board.
8 replies so far
View HerbC's profile
1727 posts in 2792 days
#1 posted 07-25-2013 03:44 PM
Do NOT use a thickness planer to attempt to flatten the twist out of an endgrain board. You will almost certainly experience catastrophic failure as the blade grabs the endgrain. It won’t be pretty and might be quite dangerous!
You might be able to fix the problem by making a router planing sled to flatten the surface again (shim up the bottom to reach a stable position, route the top flat, turn the board over and flatten the other side…
Good Luck!
Be Careful!
-- Herb, Florida - Here's why I close most messages with "Be Careful!"
View mahdee's profile
3852 posts in 1700 days
#2 posted 07-25-2013 03:52 PM
If you have a belt sander and a staight edge you can sand down the areas that straight edge reveals.
#3 posted 07-25-2013 03:55 PM
Herb, I have heard the same thing, and don’t have a thickness planer anyway. I have heard about the router method but I’m not sure I could pull it off…
mrjinx, I don’t have a belt sander but I do have a ROS. I suppose If I was patient I could accomplish the same thing…
View waho6o9's profile
8130 posts in 2510 days
#4 posted 07-25-2013 04:00 PM
View moke's profile
1128 posts in 2709 days
#5 posted 07-25-2013 04:05 PM
As mrjinx007 said…the best way is to use a straightedge….ROS with agressive paper or a belt sander….mark the areas the need help with a pencil and sand a way. I have a drumsander and if the board is big enough and the top gradually uneven, it will not help…if it is bad enough it might I think the above mentioned sand and be patient method is the best….
-- Mike
View pintodeluxe's profile
5594 posts in 2746 days
#6 posted 07-25-2013 04:58 PM
1+ router sled.
Another option is a big belt sander with a sled accessory. The sleds are available from Dewalt, Bosch etc and keep the sander from gouging the wood.
That said, when I have had small projects like cutting boards go bad, I usually just scrap them.
View Arcola60's profile
94 posts in 2317 days
#7 posted 07-25-2013 05:15 PM
I have used a router sled to do all of my end grain boards. The wood wisperer has a simple plywood design.
It works great. You can sneak up on your depth. I use double sided tape on each corner. I go clockwise
around the perimeter on the first pass to stop tear out. Then you can mill away. Then sand, sand, sand.
This is not the only way to do it. It has been very sucessful for me.
Ellery Becnel
#8 posted 07-25-2013 07:15 PM
I may have to break down and try that. I have been avoiding it because it seems like it would be easy to screw up.
