What happened here
Forum topic by natenaaron posted 07-24-2013 10:42 PM 1168 views 0 times favorited 9 replies Add to Favorites Watch
View natenaaron's profile
natenaaron
442 posts in 2038 days
07-24-2013 10:42 PM
I was sanding off the orange peel finish I created. It was getting hot and muggy and instead of sand things got gummy. I stopped right away. I got a couple fans and aimed them at the piece for a while. Worked like a charm. After sanding for a little while I thought I was done. I got the air hose to blow off the dust and the picture is what happened. Almost every board has had an adhesion issue. I put a seal coat of shellac on prior to the poly. I read and reread the can. I saw no mention of wax at all. It was Zinser’s bullseye and I sanded the heck out of the shellac. I also sanded the heck out of the first thin layer of poly.
There is no adhesion issue on the steel. Any thoughts? Notice what is under the peeling shows no sign of sanding at all.
9 replies so far
View Bill White's profile
Bill White
5149 posts in 4201 days
#1 posted 07-24-2013 10:55 PM
Bullseye and Seal Coat might be the villain.
Seal Coat is de waxed.
Might be worth the check out.
Bill
-- bill@magraphics.us
natenaaron
#2 posted 07-24-2013 11:11 PM
I used the bullseye as the seal coat. It was bullseye shellac.
View NiteWalker's profile
NiteWalker
2738 posts in 2818 days
#3 posted 07-24-2013 11:38 PM
Bullseye shellac is the waxy kind.
View Clint Searl's profile
Clint Searl
1533 posts in 2602 days
#4 posted 07-24-2013 11:55 PM
The shellac was a mistake. Poly should not be preceded by anything.
View ChuckV's profile
ChuckV
3184 posts in 3768 days
#5 posted 07-25-2013 12:32 AM
The shellac can does not say anything about wax because the natural state of shellac is to contain wax. It’s kind of like the way that nobody talks about caffeinated coffee.
The dewaxed Bullseye shellac looks like this:
I often use this under polyurethane with no problems.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
NiteWalker
#6 posted 07-25-2013 01:26 AM
I use sealcoat under waterborne poly with no problems as well.
natenaaron
#7 posted 07-25-2013 01:55 AM
That explains it. Thanks folks. Guess I now have a date with the heat gun to get the rest of this stuff off. I hate feeling stupid but at least I learned something.
View DaleM's profile
DaleM
958 posts in 3625 days
#8 posted 07-25-2013 02:40 AM
I just read the other post where you said you used acetone to thin the poly. Looking at the white in the finish and putting it all together I’m positive you were right earlier, that the acetone caused it to dry too quickly. I also think that’s what caused the adhesion problem. For those who don’t know, a fast-drying finish cools very quickly, which causes lots of condensation on the finish on hot humid days. Think of a cold drink cup. That’s what happens to the finish and causes the milky look, sometimes called blushing. The water can actually get all down into the finish, which would not allow it to adhere properly. I have had this problem in lacquer and sanding sealer before, but never poly, because the poly is slower drying so it doesn’t cool as much. Until you added acetone of course.
-- Dale Manning, Carthage, NY
natenaaron
#9 posted 07-25-2013 04:19 AM
Thanks for the info dale. The milky look showed up after sanding. If it were not for the orange peel effect there was lots of shine. That milky stuff showed up after sanding and when the heat went up with the humidity. Humidity is something I have never had to really worry about. The benefits of living in the desert I guess. I am glad this happened. I had an offer to buy the piece , even though it was not for sale, if I could fix the orange peel. I would have hated selling something that would have failed miserably. Made me feel good to have someone offer to pay for something I made.
I spent a little time with the heat gun and a little wedge of wood. Everything seemed to bubble up real nice and slide off. I will use a big putty knife nd do the job right tomorrow. I don’t like using stripper so heat gun it is foller by sanding.
