Forum topic by Jason W. Fudge | posted 07-24-2013 07:53 PM | 3372 views | 0 times favorited | 8 replies | ![]() |
If anyone has any experience with the designs below please share them. I think I finally decided on the plan for my table saw, router and planner. So I’m building a work center for my garage. In a nut shell it is going to be a table saw and router work station that I will also use as a massive table top for glueing and finishing. Then I came across this great idea with these two plans. First would have one work station with my table saw and router. As done in this plan… http://www.woodstore.net/mosaroce.html Then do a seperate work station that would have a revolving top for my planner. The planner would be kept away most of the time with just a flat surface on top. Then if I need the planner I rotate to use it. Seen in this plan… http://www.woodstore.net/flwoce.html Now the idea that brings the concepts home. Both stations would connect to each other so the rotating work station would normally be used as an outfeed table for my table saw. But when the the table top is rotated exposing my planner, the planner would line up with my table saw and my table saw would work as out feed table for the planner!! |
