Can one bend wood with a curling iron?
Forum topic by James posted 07-24-2013 05:25 PM 2413 views 0 times favorited 9 replies Add to Favorites Watch
View James's profile
James
131 posts in 1908 days
07-24-2013 05:25 PM
Can you?
-- James - Semper Fi
9 replies so far
View Loren's profile
10477 posts in 3769 days
#1 posted 07-24-2013 05:28 PM
Yes.
James
#2 posted 07-24-2013 05:33 PM
I like simple answers. But are there any concerns? Is it the same as the iron in a tail pipe device? Is it better or worse than steaming or wetting? In the future, answer my questions with 25 words or more. Kidding. But seriously, will I be happy with it?
#3 posted 07-24-2013 05:45 PM
1. Yes. Only thin wood. Maybe 1.5mm thickness.
2. I doubt it. A hot pipe probably can be got hotter, but I don’t know how hot your curling iron gets. I stick a bolt with a couple of big washers in my hot pipe to keep heat from dissipating out the end – it improves the function.
3. wetting or spritzing sometimes helps with hot pipe bending. Steaming is for thicker wood but the wood will still break if you attempt more than a very mild bend without a backing strap.
4. If you want to bend veneer, maybe.
James
#4 posted 07-24-2013 06:02 PM
I’m bending 1/32-3/64 padauk. It’s pretty bendable already but I want it to keep the shape.
I don’t understand your bolt and washers thing, Loren.
All the videos I saw of hot pipe bending, the user wet the wood just before bending.
#5 posted 07-24-2013 06:12 PM
A stone would work… just something to fill the end of the
pipe so the heat from the torch stays inside.
I usually spritz with a spray bottle when pipe bending…
it’s an art and every piece of wood is different. There
are a lot of factors at play so it’s not easy to say how
much water is enough. If the wood gets too wet it
will break.
I recommend practicing on some common woods before
attempting exotics.
James
#6 posted 07-24-2013 06:19 PM
So if I were to say I have four pieces of padauk to use and I need two to work, which method of bending would be the most efficient considering I’ve never bent wood. Having said that I’ve never bent wood, I can do anything with a youtube video and a couple forum posts preparation… like this.
View mahdee's profile
mahdee
3973 posts in 1889 days
#7 posted 07-24-2013 06:24 PM
Hi,
Best way for beding wood that I know of is to soak the wood in water over night before bending it. Pros: It bends very easily once heat is introduced and knots or waves in the wood will less likely to seperate. Cons: the wood grain will raise so some sanding is required. The wood may get darker.
-- earthartandfoods.com
View Ralph's profile
Ralph
167 posts in 2254 days
#8 posted 07-24-2013 06:24 PM
In the June 2009 (#205) issue of FWW, Michael Fortune describes how he bends wood on a heated section of 2” black pipe. He says he soaks the wood for about three hours, and that the thickest piece he bent was 3/8”.
Not exactly a curling iron, but he heats the section of pipe with a propane torch. He also says the proper temperature of the pipe is about 200°F.
Hope it helps.
-- The greatest risk is not taking one...
James
#9 posted 07-24-2013 07:19 PM
I’ll look that one up. I think with the thickness of my padauk, it should be fairly easy. And I have the two extra pieces to screw up. I’d love to get them both right so I could do all four and reinforce the sides with the extra wood.
