Router table lift choice - looking for actual reviews not router preferences
Forum topic by laketrout36 posted 07-24-2013 01:24 AM 11905 views 1 time favorited 18 replies Add to Favorites Watch
View laketrout36's profile
laketrout36
200 posts in 1994 days
07-24-2013 01:24 AM
Topic tags/keywords: router lift jessem
Last year I bought a router table and am now looking for a router lift for it. I bought the Kreg precision router table and have been looking over reviews and specs and am wondering what your feedback is based on what you currently use for a router lift. Many of the reviews quickly turn into a this or that router and the thread extends out for pages on end. Thats not what I’m hoping for. For my needs I have the Kreg precision router table and the Bosch 1617evpsk router combo. I’m leaning toward the JessEm Mast-R-Lift II.
If I’m paying out a few bucks I want to be able to;
1. Change the bit above the table.
2. Have a smooth raising and lowering of the router.
3. Solid construction.
18 replies so far
View JeanValjean's profile
JeanValjean
57 posts in 2605 days
#1 posted 07-24-2013 01:39 AM
I bought the Woodpeckers PRL V2 with the sidewinder crank for my PC 7518 router and the quality and precision are mind blowing..
I would buy it again every day of the week.
-- Semper Fi
View GNP's profile
GNP
12 posts in 2470 days
#2 posted 07-24-2013 03:17 AM
I’ve had the Jessem in Rockler blue, for the last 6 months. It meets all 3 of your requirements. It does take quite a few turns to raise it up to change the bits. Motor changes are a snap, if you want to use the motor hand held.
View johnstoneb's profile
johnstoneb
2871 posts in 2140 days
#3 posted 07-24-2013 03:23 AM
I have the Jess-em router lift II and really like it. I went with the router lift II over the Master lift II because of the price. I am not sure what the difference is between the two.
The lift mechanism is very smooth and accurate, bit changes above the table which is a real plus. I would buy it again.
-- Bruce, Boise, ID
View NiteWalker's profile
NiteWalker
2736 posts in 2544 days
#4 posted 07-24-2013 03:29 AM
Get the mast r lift II, but not the jessem version; get the incra version. It uses incra’s magnalock insert rings; none are better.
Another plus for the mast r lift II is the wide variety of router motors it accepts, should you change routers in the future. But the 1617evs is a great router.
View cpd011's profile
cpd011
90 posts in 3205 days
#5 posted 07-24-2013 03:32 AM
I have the rockler (jessem) as well. I got it on sale for $149.00. Very smooth, raised and lowers very quickly. A quality piece. My only issue with it is the height-zeroing dial, it tends to rotate with vibration. It doesn’t affect the actual bit height, but it makes it useless if your making multiple passes while raising the cutting depth. I think it is the best bang for the buck. I agree with everything GNP said.
View EdwardR's profile
EdwardR
66 posts in 2221 days
#6 posted 07-24-2013 03:43 AM
Love my woodpecker lift. I am handicapped and can not bend over to adjust the lift. solid smooth and has lock to keep set-up dead on. The micro adjust makes my life easy and the ability to pull everything above table to make changes is easy as push twist pull.
View lumberingjoe's profile
lumberingjoe
22 posts in 1915 days
#7 posted 07-24-2013 05:30 AM
I agree with NiteWalker, get the mast r lift II. The magnalock rings are absolutely the best way to go. Get the newer rings if you plan on having a dust collector under the table… they allow better dust management.
View CalgaryGeoff's profile
CalgaryGeoff
937 posts in 2449 days
#8 posted 07-24-2013 05:53 AM
Another thing to consider adding since you are getting a new lift is the digital height/depth indicator. I use two Jessem lifts, one is an entire table and the other a drop in lift. Both work for the things you want very well.
-- If you believe you can or can not do a thing, you are correct.
View bannerpond1's profile
bannerpond1
397 posts in 1866 days
#9 posted 07-24-2013 11:17 AM
I’m happy with my JessEm.
-- --Dale Page
View Rob's profile
Rob
316 posts in 2954 days
#10 posted 07-24-2013 11:55 AM
I have the Incra Master Lift II as well and as others have stated, couldn’t be happier.
View Matt Przybylski's profile
Matt Przybylski
546 posts in 2345 days
#11 posted 07-24-2013 01:04 PM
Incra Master Lift II here as well, love it. The magna lock rings are great, and as mentioned get the new ones with the DC holes. I’m going to buy the set when I incorporate under the table DC in my next router table build.
-- Matt, Arizona, http://www.reintroducing.com
View jusfine's profile
jusfine
2422 posts in 2893 days
#12 posted 07-24-2013 01:05 PM
Have used Jessem lifts for years, currently use 2 in my shop – very happy, solid and a pleasure to use.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Woodmaster1's profile
Woodmaster1
918 posts in 2554 days
#13 posted 07-24-2013 01:11 PM
I have the rockler lift works great but it will not help you. The size plate is not the same as the opening on the kreg table.
View HorizontalMike's profile
HorizontalMike
7749 posts in 2881 days
#14 posted 07-24-2013 02:17 PM
I have a 3 1/4hp Triton Router that has its own “through-the-table lifting mechanism. I had to drill the cast iron to match the crank location. The worm crank is accurate to 1/128in. when making adjustments.
http://lumberjocks.com/reviews/1983
View surfin2's profile
surfin2
51276 posts in 3103 days
#15 posted 07-24-2013 02:57 PM
MagnaLOCK Rings are the way to go…
U get above the table adjustments…
Instant ring change in a snappp…
Accuracy with cutting in increments…
Incra PRL-V2 Lift / INCRA Mast-R-Lift-II Router Lift
Depending what you feel more comfortable with, thumb wheel or hand crank…
-- Rick
