I need to make 160 mortises ( Loose Tenon )
« back to Joinery forum
Forum topic by lcurrent posted 07-24-2013 12:18 AM 3963 views 0 times favorited 14 replies Add to Favorites Watch
View lcurrent's profile
lcurrent
125 posts in 3811 days
07-24-2013 12:18 AM
The mortises need to be very accurate is there a jig that will do this ???
-- lcurrent ( It's not a mistake till you run out of wood )
14 replies so far
View Dan Lyke's profile
Dan Lyke
1520 posts in 4121 days
#1 posted 08-02-2013 11:06 PM
You don’t say much about what dimensions you need to cut, but this is what the Festool Domino family of devices is all about.
How big are the mortises? What sorts of dimensions of wood are you cutting them into? What kind of an edge are you indexing off? Do you need square corners, or can you get away with round ones?
And what do you mean by “very accurate”? That covers a lot of ground, both in terms of hole size and dimensions, placement size and dimensions, and often when people say “accurate” (close to a measurement) they mean “precise” (repeatable, but the initial measurement doesn’t matter as much). I find myself not worrying about accuracy nearly as much as precision, and if I have to be accurate I try to turn it into a problem of precision.
View pintodeluxe's profile
pintodeluxe
5654 posts in 2809 days
#2 posted 08-02-2013 11:24 PM
I use a mortising machine. I doubt if I will ever go back to using a router as my primary way of cutting mortises.
I could be talked into a Domino machine, but that won’t make through tenons.
If you are set on loose tenons, you will likely be using a router, unless you want to pop for a domino.
View AandCstyle's profile
AandCstyle
3051 posts in 2253 days
#3 posted 08-02-2013 11:43 PM
Take a look at the Mortise Pal. I have a hollow chisel mortiser and prefer the Mortise Pal.
-- Art
View fredj's profile
fredj
186 posts in 1813 days
#4 posted 08-02-2013 11:56 PM
How big a mortise ? Big ones, chain mortise machine, but there are machines built around routers that will make both the mortise and the tenon a perfect fit. I use a hollow chisel mortising machine.
-- Fredj
View HorizontalMike's profile
HorizontalMike
7755 posts in 2910 days
#5 posted 08-03-2013 01:25 AM
This works for me.
http://lumberjocks.com/projects/56897
View Domer's profile
Domer
252 posts in 3362 days
#6 posted 08-09-2013 04:53 PM
The Festool Domino is a great tool for loose tenons. It is easy and accurate. True, the tool is not inexpensive, but what is your time worth.
There is a less expensive router alternative. The Router Wizard by Eagle Tools. It works well. You can make mortises in smaller pieces with it than the Domino.
Both are great tools
View crank49's profile
crank49
4030 posts in 2967 days
#7 posted 08-09-2013 05:35 PM
The Jessem Pocket Mortise Mill II looks interesting, but is limited to one size mortise.
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
601 posts in 2903 days
#8 posted 08-09-2013 05:49 PM
PLUS 10 on the Mortise Pal
View jusfine's profile
jusfine
2422 posts in 2922 days
#9 posted 08-09-2013 06:48 PM
I also recommend the Festool Domino, I have both machines, they make short work of any loose tenon tasks.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View longgone's profile
longgone
5688 posts in 3304 days
#10 posted 08-09-2013 06:58 PM
I also have used the MortisePal for years and have been extremely happy with it. Don’t know what they sell for now but I paid around $175 for it years ago.
I have made hundreds of mortises with it without any problem or difficulty.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2068 days
#11 posted 08-09-2013 09:53 PM
Still interested in the answers to OP+1’s questions??
+1 to HM.. I do like that machine.
-- Who is John Galt?
View REL's profile
REL
76 posts in 3653 days
#12 posted 08-09-2013 10:19 PM
Domino is so easy. I found the mortisePal, I own, difficult to use.
-- REL, North Jersey
View mcase's profile
mcase
446 posts in 3125 days
#13 posted 08-10-2013 03:13 AM
I got em all. Festool, quick, accurate, convenient, also expensive and limited range only10 ml wide mortise 25 ml deep. Mortise Pal, accurate, more capacity than festool, see my review of this, also slower and you must already own a good plunge router. I also built a completley functional and accurate mortise machine wth an xy rail system. Mortiser takes time to build and money, but is fast, accurate, convenient, and has capacity knock out 1/2” wide × 3”deep x 6” mortises repetatively. My guess is the mortise pal will meet your needs. Again see my review of th mortise pal on the LJ reviews and I think you will see if it will do what you want.
View usmcshooter's profile
usmcshooter
18 posts in 1760 days
#14 posted 09-17-2013 03:45 PM
You need something that makes the Festool Domino look very slow, extremely limited, and way to expensive.
-- "It's always too soon to quit"
