Steam box volume question. Earlex steamer output.
Forum topic by Loren posted 07-23-2013 08:34 PM 1183 views 0 times favorited 6 replies Add to Favorites Watch
View Loren's profile
10477 posts in 3884 days
07-23-2013 08:34 PM
I’m building a steam box… I have some 1×6 material
I salvaged so I’ll use that.
Question is will an Earlex steamer heat a 60” long
x 4.75” inside dimension box sufficiently?
View Mark Shymanski's profile
Mark Shymanski
5623 posts in 3949 days
#1 posted 08-29-2013 03:44 AM
How did the steam box turn out? Is the Earlex up to the task?
#2 posted 08-29-2013 04:48 AM
I haven’t bent with it yet but the box does seem to be
adequately supplied. Box is in my Projects.
View RussellAP's profile
RussellAP
3104 posts in 2523 days
#3 posted 08-29-2013 12:12 PM
I used a drain pipe for my steam box. It tends to collapse if you use the green stuff, but the white holds up fine. I think you can get 6” and a couple caps and a fixture to attach the steamer to it. Easy to store away too.
View Bluepine38's profile
Bluepine38
3380 posts in 3321 days
#4 posted 08-29-2013 03:07 PM
Collapsed a white pipe last summer, will be staying with wood like Roy Underhill, wish I could use a wood
burner to create the steam like his Woodwright’s shop does.
-- As ever, Gus-the 80 yr young apprentice carpenter
#5 posted 08-29-2013 03:14 PM
My steam box. I would use
pan head screws if I did it again, or staples.
View CharlesNeil's profile
CharlesNeil
2468 posts in 4107 days
#6 posted 08-29-2013 04:17 PM
To answer the question on the steamer, yes ithe Earlex will do it , put the inlet into the center of the box, and let it steam at least an hour or more per inch of thickness. if you start to run out of water, add some boiling water and continue, ( be careful). Also remember the hour thing is after it starts steaming well .
I am basing this on the one I made to bend some material for some Morris chairs, mine was only 48 long, but it did well
