kentucky stick chair ( help!!!! )
Forum topic by Woodaholic posted 07-23-2013 11:29 AM 1095 views 1 time favorited 4 replies Add to Favorites Watch
View Woodaholic's profile
Woodaholic
16 posts in 2915 days
07-23-2013 11:29 AM
Hey guys I’m building the Kentucky stick chair. I need to know where to buy the 5/32 galvanized wire that’s used.. where did you buy it? I’ve messaged people on here just no replies :( thanks
View ChrisK's profile
ChrisK
1865 posts in 2953 days
#1 posted 07-23-2013 12:19 PM
View William's profile
William
9949 posts in 2714 days
#2 posted 07-23-2013 12:23 PM
I couldn’t find wire locally.
I used 1/8” all thread and nylon lock nuts.
View crank49's profile
crank49
4028 posts in 2842 days
#3 posted 07-23-2013 02:39 PM
If you have a Tractor Supply or Co-Op near by, they have wire called post and brace wire for fencing.
It is 9 gauge which is .1144” diameter.
5/32” is .1563” diameter; a little larger.
McMaster Carr has galvanized or stainless wire .1620” diameter, which is a little bigger.
http://www.mcmaster.com/#galvanized-wire/=nqwg0m
http://www.mcmaster.com/#stainless-steel-wire/=nqwl4a
As a side note, 5/32” is also extremely close to 4mm (3.97mm) and you might be able to fine that.
View HerbC's profile
HerbC
1707 posts in 2731 days
#4 posted 07-23-2013 05:18 PM
I used 1/8” stainless rod, which I threaded the ends of using a 6-32 die. I used stainless nyloc nuts and washers.
Good Luck.
Be Carefull.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
